1998 xjr fuel tank removal
Most unusual complaint, and one I'd like to hear about once you locate the cause. Everything is right in front of you when you remove the trunk carpets. The only difficulty is detaching the feed and return pipes from the bottom of the tank, under the car.
I just posted information about these connections a day or two ago, click on my screen name and look through recent posts: you won't have to go far before you find it.
Rlover
Mar 30, 2016 10:04 PM
