1998 XK8 surging?
Old Jun 14, 2012 | 01:57 PM
ollison's Avatar
Default 1998 XK8 surging?
1998 XK 8 surges we she is lugging 2 k up hills or at 45-50. I shift down and it helps. Where is the gas filter? Could it be that?
Old Jun 15, 2012 | 05:02 AM
hdsg's Avatar
Good day
Dont know if this will help but I did some cleaning of connectors around the throttle body. When I started the car she pulsed at idle. Went up and down in rev's. I shut the car off and disconnected the positive terminal from the battery and touched the negative with it to reset / ground the electronics. It is a procedure that has been written about here. The pulsing stopped and all was well. Of course you have to reset the windows as well after this.
Howard
Old Jun 17, 2012 | 07:09 AM
ollison's Avatar
Default How do you reset windows?
Old Jun 17, 2012 | 10:27 PM
Brutal's Avatar
with a window reseting tool.
AKA index finger press and hold each window function each window up/down. when it reaches end of travel and stops continue holding for 5 seconds. youll useally hear/feel a subtle click when reset. this resets the 1 touch feature, and 10mm drop on door opening
Old May 12, 2019 | 01:56 PM
LgcSUA's Avatar
Angry Surging
My XKR 1999 - surges whilst in park or neutral. I also get the feeling she ‘pulls’ slightly in drive. The warning lights come on and off at random which is frustrating - any ideas?
Lance
Old May 12, 2019 | 02:11 PM
RJ237's Avatar
Originally Posted by hdsg
Good day
Howard
The reset procedure is to disconnect the negative cable from the battery and touch to the positive post for several seconds. Then reconnect and turn ignition on for 30 sec. before starting.
Old May 12, 2019 | 03:42 PM
JagV8's Avatar
Please - 7yr old thread!!
Old May 12, 2019 | 04:04 PM
mhminnich's Avatar
...that was reopened by someone who is experiencing a surging problem like the original poster. What's wrong with that?
Old May 13, 2019 | 03:01 AM
JagV8's Avatar
It's a mess of a thread with a mess of answers.
If you can add help then please do...
Search might work rather better and also check the TSBs.
Pristine97XK8Convertible
Mar 5, 2025 10:32 AM
CXJ
Aug 29, 2017 08:41 AM
larrym
Dec 7, 2015 11:13 PM
Tally Ho
Oct 1, 2015 01:49 AM
Johnken
Sep 30, 2015 02:46 PM
