1999 XK8 convertible frame lube
Old Apr 20, 2021 | 07:48 PM
Markel's Avatar
Default 1999 XK8 convertible frame lube
What is the best lube to use on the frame hinges/pivot points , whatever you want to call them.
Any pointers on the best way to go about this........................................apart from 'less is more'
Old Apr 20, 2021 | 08:30 PM
jya's Avatar
jya
I have only ever used a 'Dri Lube' type of spray. Plenty of brands available. Problem I have found with oily type lubricants is that they attract dust and gum up eventually.
Old Apr 21, 2021 | 06:36 AM
Jon89's Avatar
I use white lithium grease. During 9+ years of ownership, I believe I have lubed the frame pivot points a total of three times....
Old Apr 21, 2021 | 12:17 PM
Markel's Avatar
Thanks Gents. i think i will go the dry route. l have some dry graphite lube that i use for snowmobile clutches, its aerosol bourne so it will get in there,
dwafford
Aug 17, 2017 05:10 AM
mysheroana
Jul 7, 2017 05:00 PM
LondonXK8Boy
Jul 24, 2014 02:12 PM
carelm
Aug 28, 2009 06:58 AM
