1999 XK8 Convertible throttle body gasket
Old Oct 24, 2017 | 05:06 PM
waltjag1999's Avatar
Default 1999 XK8 Convertible throttle body gasket
Called dealer to get a throttle body gasket. Dealer ask for last 6 of VIN and if car had electronic sequential port fuel injection, as there are 2 throttle body gaskets for this model. How can I tell if car has electronic sequential port fuel injection? Car is not Super Charged.
Old Oct 24, 2017 | 07:23 PM
larueb's Avatar
This is strange to me. I have a '99 and the only difference I have encountered in the air intake system is in the flexible hose from the air box to the throttle body. I purchased one from the dealer and the mounting holes on the throttle body were different so I took it back and exchanged it. Seems there is an early and late '99 flexible hose but the diameter of the throttle body intake was the same. Both mated up but only the mounting holes were different. Hope this helps.
Old Oct 25, 2017 | 02:44 AM
The diagrams in JEPC show the difference.
You're most likely to have the regular early type TB:
This is the Air Assisted TB:
Old Oct 25, 2017 | 08:02 AM
Gus's Avatar
Gus
I have reused the TB gasket with no ill effects however that is dependent on it being metal and you have not bent it.
JimC64
Sep 22, 2025 02:52 PM
Phil Preece
Oct 17, 2016 01:41 AM
sjuraud
Aug 28, 2010 02:11 PM
JimC64
Sep 10, 2009 12:44 PM
Jun 28, 2006 03:53 AM
