1999 XK8 - Restricted Performance - Coil Issues
Old Nov 18, 2016 | 01:39 PM
jag_guy's Avatar
Default 1999 XK8 - Restricted Performance - Coil Issues
Would appreciate the benefit of some wisdom..... here's the problem
After an hour driving at speed, restricted performance light comes on and car feels like it is misfiring. It will clear and return intermittently as a continue my journey.
My Jag specialist, tells me it is a coil problem, breaking down based on the codes.
Problem is that he cannot recreate it and as my 1999 model only has 2pins and no indicator as to which coil is breaking down, I need to wait till it fails completely until I get it fixed.
Given I am driving it reasonable journeys every week, its driving me nuts.
Are there any other ways of identifying which of the 8 coils are breaking down before complete failure? How much would it cost to replace all 8?
Appreciate your advice
Old Nov 18, 2016 | 03:27 PM
I would imagine you still have all 8 original coils - depending on the mileage, I would say they have served their purpose. If you use aftermarket parts, you can replace all 8 for about $300.
As this is your first post, please stop by the New member section and post an intro. In return you will receive a warm welcome and useful tips to navigate the forum
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
Old Nov 18, 2016 | 03:32 PM
I would confirm Part Number but here is a set of 8 for under $100
Jaguar XK8 XJR 97 98 2 PIN COIL STYLE OEM Ignition Coil SET OF 8 # LCA1510AB | eBay
Old Nov 19, 2016 | 04:16 AM
JagV8's Avatar
Check your battery is in great shape (rather than "starts car OK").
Old Nov 21, 2016 | 03:29 AM
jag_guy's Avatar
Thanks all, thats really helpful.
How long would it take a proper jag specialist to change 8 coils in an xk8 do you think?
