1999 xkr gearbox oil
If you have got a drain plug in the torque converter and your oil is that bad, I would definitely drain it as there will be another 2 litres or so of old fluid in there. The alternative is to use the car for a few weeks and then do the job again. I have done this repeat drain and refill on a couple of occasions but only because I have never had a TC drain.
Richard
Richard
Maybe not the most elegant way to switch out the old ATF, but effective enough.
Z
Gave up on the torque converter drain plug this morning. I need to tap out one of the pan bolts. Does anyone know the thread size? Looks like m6 x1.25 but not completely sure.
EDIT - Just checked and the last set I bought were for an X150 ZF gearbox and they were M6 x 1.0. I'm sure that the X100 is the same.
Richard
Ducmon
Feb 26, 2017 01:45 AM
