1999 xkr gearbox oil
Old May 4, 2025 | 06:36 AM
RichardS's Avatar
If you have got a drain plug in the torque converter and your oil is that bad, I would definitely drain it as there will be another 2 litres or so of old fluid in there. The alternative is to use the car for a few weeks and then do the job again. I have done this repeat drain and refill on a couple of occasions but only because I have never had a TC drain.
Richard
Old May 4, 2025 | 08:31 AM
zray's Avatar
Originally Posted by RichardS
”……..I have done this repeat drain and refill on a couple of occasions but only because I have never had a TC drain.
Richard
I do the same thing. After 3 or 4 sessions the percentage of old ATF is relatively small.
Maybe not the most elegant way to switch out the old ATF, but effective enough.
Z
Old May 5, 2025 | 04:42 AM
brinny's Avatar
Gave up on the torque converter drain plug this morning. I need to tap out one of the pan bolts. Does anyone know the thread size? Looks like m6 x1.25 but not completely sure.
Old May 5, 2025 | 05:26 AM
RichardS's Avatar
I can't remember offhand but I'm sure it won't be as large as 1.25. Probably 1.0.
EDIT - Just checked and the last set I bought were for an X150 ZF gearbox and they were M6 x 1.0. I'm sure that the X100 is the same.
Richard
Relox
Oct 28, 2024 11:42 PM
tommyknocker
Jul 15, 2023 02:23 PM
Ducmon
Feb 26, 2017 01:45 AM
Andrew5
May 14, 2015 11:45 AM
riz325
Dec 22, 2008 07:24 PM
