2 problems
Old Aug 24, 2014 | 10:43 AM
massflav's Avatar
Default 2 problems
Hello guys, i know there are nothing but scholars in here so i need help. Firstly, my jaguar xk8 03 is giving off heavy gas fumes as i drive through the air conditioning and if i roll down the window it gets worst. Any ideas what that could be or the source. Second, it says "cruise not available" on my dash. Any way i can get that back? Thank you
Old Aug 24, 2014 | 10:52 AM
DaveInVA's Avatar
Are you getting any codes with an OBD reader?
The CC problem could be that your brake light switch isn't working.
The gas smell could be a bad purge valve. Do you get a lot of pressure release when you open your gas filler cap?
Dave
Old Aug 24, 2014 | 02:59 PM
massflav's Avatar
The obd thing im not sure of, and when i open my gas cap i get no pressure release at all. And i get a message on my dash about check rear lights so is that what you are talking about with the cc?
Old Aug 24, 2014 | 03:02 PM
DaveInVA's Avatar
Your likely getting that message because the brake lights aren't working which will disable the CC.
Dave
Old Aug 24, 2014 | 05:26 PM
WhiteXKR's Avatar
'Check rear lights' in combination with 'cruise not available' messages is nearly always a bad brake pedal switch.
Agree, that you should check for OBDII codes for the gas smell for a clue. It could be the purge valve, but there is also a great deal of brittle plastic and rubber piping for the evaporation fuel system. The piping and charcoal canisters should be visually inspected under the car for damage or deterioration.
Old Sep 9, 2014 | 11:42 AM
massflav's Avatar
Is it possible to show me pictures of what these parts look like and the location so i can check them out. Also a picture of where the gas valve you guys were speaking of because i think i found the gas smell but im not sure. Thanks.also just found out my coolant is leaking again and its coming from under the resevoir somewhere. Thanks
Old Sep 10, 2014 | 04:21 AM
jamdmyers's Avatar
I just received my purge valve yesterday. Similar problem with less than 1/2 tank I'll smell fumes. There was no back pressure but this is the first FRU. Location is behind drivers side wheel liner, I'll be doing mine in a week or two.
Clamdigger
Sep 12, 2015 03:43 PM
dragonfly777
Regional
Sep 8, 2015 01:39 PM
mcdutch
Sep 4, 2015 03:38 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
