2000 XK-8 Fuel odor
Old Apr 3, 2010 | 06:50 AM
JVANNOZZI's Avatar
Default 2000 XK-8 Fuel odor
Getting a fuel smell "intermittently" while driving with top down or with
windows open on my XK-8 Roadster.
Comes and Goes !!!!
Fuel filler cap "looks OK", but perhaps a test of the cap would be in order??
I also looked in the front driverside wheel well at the hose connections to
the unit that has the vacuum switch and all connections appear to be ok.
Perhaps I should pull a vacuum test on the switch?
There are no apparent fuel leaks that I can see.
Any help is appreciated
Old Apr 3, 2010 | 08:48 AM
blrunner's Avatar
JVANNOZZI,
You should introduce yourself at the new member area and this post should be put in the XK8 section and I'm sure you will get lots of help.
Old Apr 3, 2010 | 04:01 PM
JVANNOZZI's Avatar
Default Xk-8
Hank;
I thought I did post on the XK8-XKR area of the forum ???
Joe Vannozzi
Old Apr 3, 2010 | 05:12 PM
blrunner's Avatar
I would help you if I had any answers but. Is your gas tank full, it doesn't take much fuel to get a smell, post it in the XK8 forum where everyone looks in. Probable just the North east people look here. Sorry I can't help.
Old Apr 3, 2010 | 11:42 PM
H20boy's Avatar
moved you over joe!
There are several threads dealing with 'odor' coming under hard acceleration, but only theories and myths as to their cause, no absolute determination.
Old Apr 4, 2010 | 10:15 AM
motorcarman's Avatar
Call a dealer with your VIN and find out if S841 has been performed. Could be a vapor issue with the EVAP system
Corroded Filter Vent Pipe .
Canister Close Valve .
Service Action S841
Old Apr 4, 2010 | 07:08 PM
JVANNOZZI's Avatar
Default Canister Close Valve
Where is this located so I can check for corrosion ???
Joe V
JWheeler
Nov 22, 2019 08:28 AM
Tim Goz
Sep 17, 2015 09:11 AM
Andrew Fanshawe
Sep 14, 2015 07:40 PM
Super Cat
Sep 9, 2015 03:24 PM
stype40
Sep 9, 2015 08:14 AM
