2000 xk8 headlight switch replacement
Old Feb 24, 2025 | 05:50 PM
joekluger's Avatar
Default 2000 xk8 headlight switch replacement
Just got a 2000 xk8. While driving at night the dash lights and headlights flicker. Standing still there are no issues. I'm assuming a bad headlight switch. Am I assuming correctly? I'm looking for switch removal instructions. Been searching but could not find any. Any help. Thanks
Old Feb 24, 2025 | 09:43 PM
MVMonarch's Avatar
Flickering obviously sounds like a loose connection in the circuit. Can you reproduce the symptoms by wiggling the stalk or associated wiring? I wouldn’t replace the stalk switch without further investigation and research.
Old Feb 25, 2025 | 07:44 AM
JimmyL's Avatar
You probably making the correct assumption. A little solder might do the trick. ^^ try wiggling the stalk. I did this once, but I don't recall too much about it. This is from the X308 forum, but it might help -
Turn Signal Stalk Resoldering - Jaguar Forums - Jaguar Enthusiasts Forum
Old Feb 25, 2025 | 08:02 AM
joekluger's Avatar
Do you have to remove the steering wheel to pull the switch out?
Old Feb 25, 2025 | 08:14 AM
kstevusa's Avatar
Possibly will need to but one can tell after one removes the U&L Cowls. There are directions in my posts regarding the R&I Column Drive Cable and R&I the steering angle sensor SAS. Also, remember a Pozi Drive not Phillips screwdriver.
Old Feb 25, 2025 | 10:53 AM
bladerunner919's Avatar
No, you don't. Just the cowling around the switches.
bfrank1972
Oct 7, 2024 12:09 PM
Clayxj
Dec 8, 2019 02:44 PM
DRober0
Oct 25, 2019 06:08 PM
Rhett
Nov 16, 2017 10:34 AM
05XK8cfe
Jun 14, 2015 01:55 PM
