2000 XK8 Idler Pulley Replacement
Old Dec 11, 2015 | 11:59 AM
Flyboygus's Avatar
Default 2000 XK8 Idler Pulley Replacement
Oh great Oracle of all things good,
Does anyone have a clever way of removing the retaining clip for the Idler Pulley?
I am trying to be proactive and replace both Pulleys (one is making a noise).
Idler Pulley Retainer Clip
Old Dec 11, 2015 | 02:57 PM
Gus's Avatar
Gus
If this is on the tensioner just replace the entire unit.
Old Dec 11, 2015 | 03:33 PM
Flyboygus's Avatar
Gus,
Thank you, but this is not the tensioner pulley, but the other one.
Old Dec 11, 2015 | 09:16 PM
Gus's Avatar
Gus
Did it not come with a bolt attached?
Old Dec 12, 2015 | 07:32 AM
mrplow58's Avatar
Some folks just like to shed blood, when they replace those 2 pulleys Gus. Nothing like turning a 20 minute job into something over an hour, and a possible ride to the ER.......Best of luck.......Mike
Old Dec 12, 2015 | 07:54 AM
cjd777's Avatar
Flyboy, I don't think that is suppose to be there. I can see you have given it the great effort and other than sticking a screwdriver in there to open it up, I would be stumped.
Maybe chisel the other side, off course that would require you to make one or grind a small one down.
Let us know.
Wayne
Old Dec 12, 2015 | 02:21 PM
Flyboygus's Avatar
Dear Gus,
I have had to order two of these to get the correct width for the serpentine belt and none of them come with a bolt.
Wayne,
I think you are correct, what should be simple, will take longer than expected. Sounds like I am the pioneer this time.
I will keep you posted.
Old Dec 12, 2015 | 03:59 PM
plums's Avatar
If you mean the corrugated snap ring affair, just pry it out or use snap ring pliers.
You don't need it afterwards as it only serves to keep the bolt with the pulley
during factory assembly. Works fine without it.
As for why someone would want to replace bearings only, sometimes the pulleys
that are already there are better quality. And they are guaranteed to be the
right configuration. There are multiple configurations used on the 4.0L SC.
On a straight bearing replace, count on doing all 4 for $20 or so.
Old Dec 12, 2015 | 05:42 PM
Flyboygus's Avatar
Smile 2000 XK8 Idler Pulley Replacement
Mystery Solved!
I tried removing what looked like a retainer clip, then I had a thought, what about brute force,,,, just kidding.
I took the pulley, placed it between two scrap 2X4 pieces and gently taped the bolt with a hammer and it popped out as easy as you please.
When ordering a replacement pulley, they come with a new bearing already pressed in. What I thought was a retainer clip turned out to be a synthetic spacer that is pressed into the inside of the bearing. Once you pop the bolt out, you can unscrew this spacer and wire brush the bolt, then put the spacer back on. TADA
Here is what the spacer looks like off the bolt:
CharlzO
Jun 6, 2020 04:07 PM
sonicd0012
Dec 17, 2015 04:15 PM
RDMinor
Dec 12, 2015 10:27 PM
auburn2
Dec 12, 2015 08:33 AM
Johnken
Dec 11, 2015 01:34 PM
