2000 xkr bremo or not bremo
Old Apr 22, 2009 | 06:56 PM
JgaXkr's Avatar
Default Brembo brakes
Brembo brakes were not available until 2001 & then only the Silverstone, in 2002 on the XKR-100. In model year 2003 you could order them as an option. I have listed as set of Brembo calipers in the classified section that will bolt straight on to your car. It does make quite a difference.
Old Aug 15, 2009 | 08:51 AM
JgaXkr's Avatar
If I remember for the front you need to replace the front dust shields & brake hoses only. This is assuming you have the radial mount Silverstone calipers, these have the word Jaguar in red on the caliper. If not you will have to have the caliper mount holes tapped out. I had that set up on my car & it is a true bolt on setup. The rears you need to modify the rear dust shields, just trim off the lip, otherwise again a straight bolt on. You also need the new braided brake hoses for the rear as well. Hope this helps.
peterg19
Feb 10, 2023 09:02 PM
hhv00586
Sep 18, 2015 08:59 AM
Super Cat
Sep 9, 2015 03:24 PM
stype40
Sep 9, 2015 08:14 AM
Xkr x100
Sep 6, 2015 08:50 AM
