2000 XKR Coil Packs
Old Mar 11, 2022 | 08:24 AM
Gerard's Avatar
Default 2000 XKR Coil Packs
Are the 2 pin and 4 pin Coil packs interchangeable? Is there a way to wire them? I have 2 pin on my car but the spare coil [acks I have are 4 pin.
Old Mar 11, 2022 | 10:17 AM
NBCat's Avatar
The injectors are controlled by the PCM and must be compatible with the wiring loom on the vehicle. If the vehicle is fitted with the 2-pin injectors, they must be replaced with injectors with the same configuration.
Old Mar 11, 2022 | 10:30 AM
Gerard's Avatar
Thank you, I will get the correct ones!
Old Mar 11, 2022 | 12:15 PM
motorcarman's Avatar
The 2 pin coils have a control module for EACH bank. (two controller/amplifiers)
The 4 pin coils have the controller/feedback built-in so the ECM has the full authority and does not need the external ones.
Old Mar 12, 2022 | 06:15 AM
Gerard's Avatar
Thank you!
JigJag
Jun 3, 2023 12:42 PM
alanroberts50
Jul 7, 2020 07:13 AM
dstjohn
Nov 15, 2015 12:58 PM
Mjoseph420
Jan 16, 2015 09:16 AM
wnlewis
Apr 2, 2009 10:17 PM
