2000, xkr, ecu
Old Nov 27, 2024 | 02:28 PM
feilding's Avatar
Default 2000, xkr, ecu
I have a 2000, XKR with a faulty ABS - TRAC ECU module. We tried the resoldering the power pin joints, but this did not cure the fault.
My unit is maked as a LNF2210AC and I am having trouble locating a replacement. I have found a number of
LNF2210AD units. Does any body know if these are interchangable? I would be grateful for any advice.
I am aware that there are exchange services avaiable but I asume because mine has been tampered with that this is no longer an option!
Old Nov 27, 2024 | 04:24 PM
motorcarman's Avatar
You should have a 6 pipe (9 valve) ABS control module.
The ACTUAL Jaguar part number you have/need is JLM21323.
The numbers on the case are NOT jaguar part numbers.
ANY X308 or 4.0 X100 from 2000MY onward will work.
I compiled a list of correct ABS modules.
File Type: pdf
Old Dec 1, 2024 | 09:14 PM
feilding's Avatar
Smile motorcarman;2804810: Thank-you so much for your assistance, greatly appreciated!
That makes sense.
KRNW
Apr 5, 2025 03:18 PM
User 070620
Dec 14, 2018 02:19 AM
The jive dancer
Jan 8, 2016 04:12 PM
adam699
Nov 25, 2012 09:55 AM
