2000XKR More messages than I can handle
Old May 15, 2012 | 03:54 PM
Super Cat's Avatar
Default 2000XKR More messages than I can handle
I just finished several repairs and reconnected my battery. I haven't even turned on the key and the message center is displaying every fault known to man. Disconnected and reconnected the battery several times making sure not to break the initial connection. Would a "Hard Reset" possibly fix the problem? What is the procedure? Would I then have to visit the dealer for reprogramming? Thanks in advance!
Old May 15, 2012 | 04:08 PM
Super Cat's Avatar
I just found the Hard reset procedure so sorry I posted for that info. I will try that tonight. However, is there anything else I might try if the rest doesn't solve the problem?
Old May 15, 2012 | 04:49 PM
The Coupe's Avatar
Don't know what work you've done, but you might want to go back over everything very carefully and make sure you've reconnected everything, replaced any fuses you may have taken out, etc.
Hopefully the hard reset will do the trick...but I've seen similar behavior when I had forgotten to replace a fuse I had removed.
Old May 15, 2012 | 05:27 PM
Make sure the battery is fully charged also, especially if it has been disconnected for some time.
Old May 17, 2012 | 12:45 AM
Super Cat's Avatar
OK, battery is fully charged and I tried the Hard reset - no luck. Can't connect to OBD. What I was working on was replacing hydraulic hoses from top latch to pump, installing pressure relief valve, and replacing stereo amplifier - so seats, carpet, rear quarter panels, trunk interior, center console, left passanger fuse block, stereo/ nav equipment from trunk was removed. I didn't find anything wrong yet but am still working on it. Any thoughts are appreciated.
Old May 17, 2012 | 01:04 AM
avos's Avatar
What messages do you get?
Edit: Just reread your first post, I guess you have tripped your inertia switch. Just push the button of it, it will probably solve it all.
Here you see the switch on the right side of the fuse box:
Old May 17, 2012 | 08:11 AM
Super Cat's Avatar
Avos, You are the man once again! Pressed the button, problem solved.
Thank you!
Old May 17, 2012 | 12:52 PM
avos's Avatar
No Problem, but please don't ask me how long it took me to resolve this issue on my car...
Old May 17, 2012 | 07:31 PM
Bills's Avatar
Amazing!!!
Old May 17, 2012 | 07:40 PM
Vector's Avatar
WOW! Nice work, guys!
Vector
Old May 17, 2012 | 08:30 PM
MR. CJ's Avatar
I wish all problems were this simple, and cheap to fix.
Old May 17, 2012 | 10:06 PM
Beav's Avatar
If you don't have an owner's manual you may not know that when reconnecting the battery you need to allow it to remain connected for 30 seconds or so (too lazy to go out in the garage and look it up.) The computers can get freaked-out if not allowed to fully boot. Personally, I allow a couple minutes betweendisconnect/reconnect on any car. I'd hate to have to explain why an airbag deployed randomly while I was working on a car... (don't know if it could happen but I've seen a lot of other weird things happen to good techs.)
magmedia
Aug 15, 2019 08:54 PM
NS2000XKR
Jan 1, 2017 10:41 AM
jagxk2008
Feb 4, 2016 09:53 AM
10 XF Premium
Oct 2, 2015 09:22 PM
