2001 Jag XK-8 w4.0 nonSC - water pump recommendation?
Old Dec 5, 2013 | 10:57 AM
Scott M's Avatar
Default 2001 Jag XK-8 w4.0 nonSC - water pump recommendation?
I have seen many replacement water pumps for this engine. Does anyone have a suggestion as to which is the best? Plastic or metal impeller ect?
Old Dec 5, 2013 | 11:00 AM
Scott,
I've moved your question from General Tech Help to XK8/XKR forum. Members here with the same model will be able to help.
Old Dec 5, 2013 | 05:33 PM
All Jaguar OE water pumps have plastic impellers.
The plastic impellers on the very early XK8/XKR water pumps were known to break up but Jaguar revised the spec and this issue has long since disappeared.
There are aftermarket ones available with metal impellers but several members have reported problems with wear on these.
The usual recommendation is to go for a pump with a plastic impeller.
Old Dec 5, 2013 | 06:41 PM
ccfulton's Avatar
The Jaguar OEM one is probably the "safest" option, and as Graham said, only the very early models had any issue.
I was doing some other work and preemptively changed the water pump on my 4.2L. It looked perfectly fine after 70k miles.
The AC Delco one I replaced it with didn't fare so well. The impeller had a hairline crack which, within a thousand miles, let it slip on the shaft and cause an overheat problem.
I then replaced it with a Beck Arnley metal impeller type, which has gone a few thousand miles without any problems.
Old Dec 6, 2013 | 01:21 AM
avos's Avatar
Besides low quality metal impellers on the market, OAT coolants (recommended coolant for your engine) don't offer good protection against cavitation for the metal impellers.
So long term these will not be safe (don't ask me how many miles), unless you switch to a coolant that also has anti cavitation inhibitors, or check your pump and swap once the impellers are corroded too much.
Metal impeller ones where used on the Ford 3.9 Lincoln engines, but these engines use a hoat type of coolant (with silica which is known to help against cavitation)
Stick with the oem waterpump with plastic impellers, then you are safe long-term.
toronadomike
Jan 22, 2026 10:13 PM
D.K
Dec 10, 2023 02:05 AM
Sprayall
May 30, 2021 08:13 AM
allenman85
May 10, 2021 03:11 PM
Sprayall
Sep 3, 2015 07:49 PM
