2001 Jaguar XK8 4.2l engine upgrade
Old Feb 24, 2015 | 02:59 PM
Kearnice's Avatar
Default 2001 Jaguar XK8 4.2l engine upgrade
With the help of Voss (really kool kat), I have finished the install of an engine upgrade from the 4.0l to the 4.2l.
The car ran for days ...began to stall immediately after I added gas in the tank
I need help resolving the following..
- The engine starts but it stalls during idle
- The throttle body has been replaced
- I have had the ECU checked and it has a bad processor or "processor failure" as I was told
- A new ECU has been purchased but it needs to be flashed to my car.
The local dealership will not take this on...
I have the IDS software but I don't know how to use it for this
The dealership told me IDS does not recognize my VIN because of "sub-sections needing to be added"
What can I do to flash the replacement ECU so I can get this car driving again?
codes p1797, p1638, p1642, p0052
KT
Old Feb 24, 2015 | 03:48 PM
brgjag's Avatar
I did not know it was possible to put a 4.2 in a 4.0 car. I did not think an ECU from either motor would work with the other. Wiring issues? Trans Module diff?
Old Feb 24, 2015 | 03:50 PM
brgjag's Avatar
Are there not CAN/BUS (using correct words?) system diff from an 4.2 to 4.0 cars such as Jag Specialties has not mad a conversion kit for GM LSx motors for 03 and newer xk8's???
Old Feb 24, 2015 | 04:21 PM
RCSign's Avatar
I thought there was a post about using the 4.2 short block only. on the earlier series
Old Feb 24, 2015 | 04:24 PM
Kearnice's Avatar
I am only using the 4.2l block with modifications using 4.0l parts.
The cable interfaces match as well
Then the focus turned to the Throttle Body and the ECU
detXJ
May 22, 2016 10:50 PM
celticpiping
Sep 18, 2015 06:17 PM
Goncalo Proenca
Aug 27, 2015 03:55 PM
dpappyp
Aug 27, 2015 06:31 AM
souldoubt
Aug 25, 2015 08:15 PM
