2001 tensioners
Old Apr 19, 2015 | 06:09 PM
noonblueapples's Avatar
Default 2001 tensioners
Hi.
Having owned some jaguars from the 80's I am now looking at a 2001 XKR. Skimming thru the forums it looks as though this has an updated though still bad set of tensioners.
Am I correct that this car would just need the easy to reach tensioners under the valve cover replaced with metal ones? Thanks
Old Apr 19, 2015 | 06:36 PM
RJ237's Avatar
You are sort of correct. The primary tensioners are not subjected to as much heat and do not fail as quickly. Also, when they do fail it is not likely to result in catastrophic engine damage. The chain guides are subject to cracking and may fail also.
Most of us have replaced the secondaries and will do the rest when they fail, if ever.
Old Apr 19, 2015 | 07:48 PM
Old Apr 19, 2015 | 09:12 PM
stevepaa's Avatar
I have a 2001 with 90k miles and bit the bullet last year and did all chains and ramps. I found one chain had jumped one sprocket over the years and the ramps were cracked. plastic just degrades with time and heat
Old Apr 21, 2015 | 03:33 AM
dibbit's Avatar
This is a job I am looking at doing this year as the car approaches it's 15th birthday. Did you do the job yourself and how long did it take?
Old Apr 21, 2015 | 04:49 AM
test point's Avatar
While an experienced hobby mechanic I had never worked on a Jaguar engine before my tensioner effort. It took 4 hours to do the secondary tensioners using the Jaguar specified cam alignment tools. That included engine detail along the way.
Old Apr 23, 2015 | 01:16 PM
stevepaa's Avatar
well, several days as other things got my attention. I think you can do it in two days. be sure you have all the tools necessary before you begin.
Old Apr 23, 2015 | 02:29 PM
EZDriver's Avatar
I don't understand why anyone would use the special tool, Jaguar method for changing the secondary tensioners. The zip tie method is so easy and well documented with photos and description.
Old Apr 24, 2015 | 07:18 PM
stevepaa's Avatar
zip tie is fine for secondaries
Old Apr 24, 2015 | 08:38 PM
test point's Avatar
Zip ties had apparently not been invented when I did my tensioners or at least not applied to this problem.
If there is any question on cam to crank alignment the hold down tools are absolutely necessary.
sadepol01
16
Nov 22, 2024 05:05 PM
mikiep
Dec 20, 2019 07:37 PM
k-man
Oct 5, 2015 08:09 AM
millertic
Sep 30, 2015 08:11 PM
dpappyp
Sep 29, 2015 01:28 PM
