2001 XK8 Electrical wiring diagram question....
Old Jun 17, 2011 | 05:28 PM
Magnetvision's Avatar
Default 2001 XK8 Electrical wiring diagram question....
I have a 2001 XK8 Convertible with the Premium Alpine system, and when I pulled the radio out to inspect the wiring harness, the wiring diagram that I have shows IC-8 with a red wire on pin 3 and a yellow wire on pin 7. Normally on most vehicles these should be Radio switch..(ignition) wire (red) and 12 Volt Constant (yellow). Both of these wire show to go directly to the power amplifier in the rear of the vehicle. Also on IC-19 There is a Brown/Red wire on pin 1 and a Brown/Red wire on pin 2. One of these Brown/Red wires goes to the fuse box on the passenger side to a 10A fuse and the other Brown/Red wire goes to the trunk fuse box to a 5A fuse.
My question is...which of these wires would be used for Radio switch, and which would be used for 12 volt constant. I hope I'm not sounding too confusing, but I want to connect the wiring harness from an aftermarket stereo to 12 volt constant and Radio switching (ignition-off/on). Anyone had experience with this issue...? (I've already identified the ground wire on IC-19..on pin-0...that one was easy....).Can anyone help?.....
Old Jun 17, 2011 | 07:17 PM
WhiteXKR's Avatar
IC-8 is part of the Alpine AI-Net. Do not try to use that for power, it is only meant for low power devices like the CD changer, and is in a jacketed multi-conductor cable.
Non-switched battery power is on both IC-19 pins 1 and 2 (both brown-red). They actually go to the same passenger side fuse. (The square boxes in the diagram indicate they are direct battery (unswitched) feeds).
IC-19 pin 7 is ignition switched (a white wire). The circle it connects to in the diagram indicates it is ignition switched, and the 'I' at the botton of the circle means it is switched on in the first ignition position.
The ground is actually IC-19, pin 6, (black). There is no pin 0.
Old Jun 17, 2011 | 10:32 PM
IC-19 pin 7 is ignition switched (a white wire). The circle it connects to in the diagram indicates it is ignition switched, .and the 'I' at the botton of the circle means it is switched on in the first ignition position.
Looking at the diagram I have for 2001 XK8 Convertible w/Premium Alpine System, does not show a pin 7 on IC-19. There is also no reference to a White wire. The diagram I have only show pins 1 thru 6 on IC-19. Are you sure there is white wire on IC-19, pin 7 ? Not doubting you...just want to make sure....maybe I have the wrong diagram.....I really need to know which wire is ignition switched. I really appreciate your help....
Old Jun 17, 2011 | 11:12 PM
One more thing....pin 1 on IC-20 shows to be an Orange/Yellow wire which goes to the "Instrument Pack". Since I don't plan to use any of these pins on IC-20....does this wire need to be connected to anything ? Is it essential that it be used ?
Old Jun 17, 2011 | 11:24 PM
Oh....never mind...I see it....(feelin kinda stupid now). Thank you sir....
Old Jun 18, 2011 | 06:53 AM
WhiteXKR's Avatar
No, thats just a speed input for speed dependent audio volume. You do not need to connect it.
toronadomike
Jan 22, 2026 10:13 PM
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
danpop
XJ40 ( XJ81 )
Sep 8, 2015 03:23 PM
YycXJS
Sep 7, 2015 09:58 AM
