2001 xk8 jaguar non s/c NO START!!
Old Aug 8, 2015 | 02:15 PM
Originally Posted by WhiteXKR
This kind of problem is difficult to solve remotely, but if it was me I would unplug various modules one at a time as well as the ignition switch and see if the Ecu fan goes off. I would start with the BCM and the main instrument cluster as most likely to cause this kind of issue.
Your battery is draining rapidly so if you do this yourself you may need a charger or low battery will complicate the situation further.
You don't want to go buying modules you don't need.
Old Aug 8, 2015 | 02:24 PM
WhiteXKR's Avatar
Originally Posted by yusuf benallal
So swap out bcm?
No, read what I wrote yesterday. Remove it and see if the short clears (ie; if the ECU and ECU fan powers down. If it does, that is evidence that it is causing the problem. Disconnect the battery during removal and reconnect it afterwards to avoid further problems.
As Norri said, you should not buy modules unless you positively have evidence that they are bad.
Old Aug 11, 2015 | 04:42 AM
yusuf benallal's Avatar
My best armchair guess based on the circumstances you described is a module fried (most likely the BCM or instrument cluster), or the ignition switch contacts were overloaded and damaged, or a wire melted and shorted to the chassis.
The advice is worth what you pay for it That is all I can say now....you are free to do what you want.
I unplugged the bcm and it didn't seem to change anything. Still the throttle body is humming constantly and the ecu and ecu fan is running. I swapped batteries just incase and no luck. I did graphite on the key flap and no changes either. Any other ideas?
celticpiping
Sep 18, 2015 06:17 PM
msdg137
Sep 16, 2015 06:24 AM
1964Daimler
Sep 2, 2015 11:41 PM
dpappyp
Aug 27, 2015 06:31 AM
Terrance Williams
Aug 26, 2015 11:50 AM
