2002 jaguar Xkr abs/trac light
Old Apr 14, 2012 | 12:07 PM
lcyoung's Avatar
Default 2002 jaguar Xkr abs/trac light
I have a 2002 jaguar xkr the abs and traction control light on. What can cause these light to come on. Everything working fast
Old Apr 14, 2012 | 12:33 PM
roymattblack's Avatar
Is the light on all the time, or just when you pull away or corner?
If it's the latter, it's quite normal - your traction control is cutting in to handle the power. Try easing your right foot!
Roy
Old Nov 5, 2013 | 01:25 AM
jagman01's Avatar
Post 2002 Jaguar XKR Traction control/ sac lights on
I have had H&R lowering springs placed on my vehicle. I was getting an error code for the abs module and sent it out for rebuild. I am getting a check engine light and code C1175 I believe that to be the rear wheel speed sensor. I cleaned the sensor rear left and swapped it with the front left. The fault code is the same C1175 and a check engine light. Any ideas what could be the cause?
Old Nov 5, 2013 | 03:48 AM
The codes are wheel position specific.
C1175 is LH Rear electrical failure. This fault has the following possible causes:
1. Wheel speed sensor open or short circuit
2. Wheel speed sensor to CM circuit: high resistance, open circuit or short circuit to ground
3. Wheel speed sensor failure
4. CM failure
By swapping LH sensors front to rear, the code should have changed to C1155 if the sensor was faulty. As it's stayed the same, this suggests a harness fault is the next thing to investigate and eliminate.
Old Nov 5, 2013 | 08:01 AM
oldmots's Avatar
To diagnose a fault in the ABS system, you will need a code reader that reads ABS codes. The most likley failure of this system is a bad wiring harness from a wheel sensor to the body (always moving and the wire breaks), but without the code, you will just be throwing expensive parts at it.
Old Nov 6, 2013 | 09:38 PM
JeffsJag's Avatar
An older battery can trigger a light, in my case (2001 XK8 Coupe) I could put a charger on the battery for a few hours and upon the next restart the warning light would be gone. It won't cost you anything to try.
Good luck
Old Nov 16, 2013 | 02:59 AM
jagman01's Avatar
Default C1175 code cleared
Thanks for your help. I Tried clearing the codes one more time and was successful. The company that rebuilt my ABS module said to drive it for awhile. I put about 300 miles on it before I was able to clear the codes. I have been driving it the last 4 days without problems now an have put an additional 150 miles on the vehicle.
Old Aug 24, 2014 | 05:10 PM
ryejag's Avatar
My code reader will not read ABS codes. Any recommendations on what readers will work with a Jag? Having issues with ABS light on my 2004 XJR.
RyeJag
Old Sep 22, 2014 | 01:44 PM
jagman01's Avatar
Default code reader
I am presently using the Logworks wireless reader by Innovate Motorsport. the software is purchased as an app. and the reader is purchased also. It can be read on your phone or on your computer,Ipad or other device. It works with my 2001 XKR,my 2004 Lincoln Navigator, 2009 Scion XB but not with my 2004 Land Rover Discovery II ( they tend to be more temperamental). I am not 100% sold on this reader. I recommend doing more research.
Old Sep 23, 2014 | 07:07 AM
ryejag's Avatar
will it read ABS codes?
Old Sep 23, 2014 | 02:06 PM
jagman01's Avatar
Default Code Reader
the logworks device reads codes and has other functions such as GPS based dyno,economy,speed timing capabilities. I would recomend online research for a better description. I have used it to diagnose ABS. I sent my ABS/traction control module in and had it repaired. Problem was solved,lean codes on engine banks which were caused by a small crack on the bottom of my intake plenum ( where the flexible ribs are).Brake light switch diagnosed and replaced. There were probably a few other items that I don't remember right now. Hope this helps.
Old Sep 24, 2014 | 07:39 AM
ryejag's Avatar
jagman01
curious how you found the leak in the intake plenum. I have the lean code issue on and off.
So you were able to read ABS codes on the device? and it lead you to the module?
thanks
RyeJag
Old Sep 24, 2014 | 07:42 AM
ryejag's Avatar
jagman01
where did you send your ABS module for repair?
anyone else have experience with ABS module repairs?
RyeJag
Old Sep 24, 2014 | 09:01 AM
RJ237's Avatar
The majority of abs repairs are to the pump solder connection and there are several services that can be found on ebay. Many of the members have repaired their own. My preferred method is to cat a hole in in the case opposite the pins.
JagRepair.com - Jaguar Repair Information Resource
Old Oct 1, 2014 | 12:08 PM
jagman01's Avatar
Default ABS Module
Hi Ryejag,
I have sent 2 ABS Modules to BBA-Reman in Mass. for repair and been happy with their service.
As far as diagnosing the intake leak, I was getting a lean code for right and left banks. This meant more air was going into the throttle body than the mass air flow sensor was measuring. I looked up threads on the forum for possible causes.That is the reason that I took off the air intake tube or plenum and found cracks in between the bellows or folds of the plastic.
I hope this helps.
Griffbritgreen
Jul 27, 2016 05:43 AM
h4wk
Nov 27, 2015 05:10 PM
montypeek
Sep 6, 2015 04:57 PM
roumor
Aug 28, 2015 01:02 PM
divingmom
Aug 25, 2015 07:54 PM
