2002 XKR w/37k, what is making this sound?
Old Feb 9, 2015 | 03:11 PM
guzzi svt's Avatar
Default 2002 XKR w/37k, what is making this sound?
I saw this on EBay and was interested enough to call, he sent me to youtube to listen to it run?!?!
Old Feb 9, 2015 | 06:06 PM
stevepaa's Avatar
water pump or tensioner pulley?
Old Feb 9, 2015 | 06:25 PM
Cee Jay's Avatar
They said the belt was off, can't be the water pump or tensioner. Nor the alternator.
Old Feb 9, 2015 | 07:14 PM
brgjag's Avatar
wrecked jag, noisy and how many times has it been run in this state? I would RUN not walk from this car.
Old Feb 9, 2015 | 07:58 PM
batroute's Avatar
If it's pumping out oil surely there would be no oil pressure? Therefore the hydraulic timing chain tensioners wouldn't be taking the slap out of the chains? Whatever it is he shouldn't be running the engine without oil.
Old Feb 9, 2015 | 08:06 PM
stetson1's Avatar
good sense would insist that you send a thank you for the youtube and tell them you're not interested. there are too many other nice ones out there to get stuck with that one. UNLESS, you simply need a parts car and price is less than $3k.
Old Feb 10, 2015 | 08:34 AM
guzzi svt's Avatar
Thanks for the info on the cam chain tensioners. That would explain the rattling.
Well I'm not going to buy it, I'm amazed at how noisy the engine was with so low of mileage. If it's an oil pressure problem not pumping up the tensioners it would be worth his while to install a bypass hose on the oil cooler and take a new video, but he said he wasn't going to do any other work on the car to sell the engine "someone who can appreciate this engine for what it is will buy it". If he would spend a few minutes fixing the oil leak and it sounded better I might buy it, but not the way it sounds now!
Old Feb 11, 2015 | 07:42 AM
guzzi svt's Avatar
Do all of the cam chain tensioners work off of oil pressure? I'm am only familiar with motorcycles which use a spring for tension.
Old Feb 11, 2015 | 11:34 AM
brgjag's Avatar
That is what gets me with some sellers. "All you need to do it is buy a 40 dollar part to fix it and it will be a great car" ha ha ha then why don't ya fix it then before you sell it. I walk away or dont even go looks at most ALL cars that say this that are for sale.
Old Feb 11, 2015 | 12:16 PM
batroute's Avatar
Top(secondary) tensioners have a spring to keep static tension on the chains, then oil pressure takes over once the engine starts. Bottom(primary) tensioners are pure hydraulic with a non return valve.
Old Feb 11, 2015 | 03:12 PM
guzzi svt's Avatar
Thanks for the information, that would explain the noise.
way2far
Aug 31, 2022 09:26 AM
SD96XJ6L
Jan 12, 2022 04:30 AM
mbergen
Oct 23, 2019 10:26 PM
obwoodie
Sep 3, 2015 07:45 PM
colorancher
Sep 3, 2015 02:29 PM
