2003 Auto Dim/Rain sensor Rview Mirror lifting off
Old Aug 29, 2014 | 12:20 PM
brgjag's Avatar
Default 2003 Auto Dim/Rain sensor Rview Mirror lifting off
I have the auto dim/rain sensor rear view mirror. In this pics you can see that it is detaching right in the middle on bother sides of the round part in the pic. How can I make that restick. Right now the mirror is hanging on from the bottom and some a few sticky back things I put on to help hold it in place.
Attached Thumbnails 2003 Auto Dim/Rain sensor Rview Mirror lifting off-imag1528.jpg   2003 Auto Dim/Rain sensor Rview Mirror lifting off-imag1529.jpg
Old Aug 29, 2014 | 05:51 PM
brgjag's Avatar
Well wife said she saw black drops today from the mirror so I have removed it as it was about to fall off now. Where is this black drop of fluid coming from? The round EYE I guess you call it it still on the windshield, is that where the JUICE is dropping from?
How do I reattach this thing?
Old Aug 29, 2014 | 05:52 PM
brgjag's Avatar
seems like some type of glue would hold it in place.
Old Aug 29, 2014 | 07:19 PM
WhiteXKR's Avatar
There is a special adhesive pad you can get from a Jag dealer. See: Jaguar Parts - Direct JPLV Porsche Parts.com
Old Aug 29, 2014 | 07:39 PM
brgjag's Avatar
it says it is for XJ cars. Will it work with the XK set up.
Old Aug 29, 2014 | 07:49 PM
brgjag's Avatar
What is leaking, from where? My sensor thing is still on the window.
Old Aug 29, 2014 | 07:55 PM
brgjag's Avatar
from what I have found there is a gel that can be used now to hold up the mirror replacing the electromatic stuff?
Old Aug 29, 2014 | 08:51 PM
WhiteXKR's Avatar
Pretty sure it is correct. It worked in this thread: https://www.jaguarforums.com/forum/x...-bumps-103725/, but this is not what holds the mirror up, just the rain sensing disk.
You need to get that mirror out of the car and get it repaired. The liquid is caustic, wear gloves.
Old Aug 29, 2014 | 09:02 PM
brgjag's Avatar
I guess I am not getting this. The mirror is out of the car. Where is the bad liquid coming from??? The round thing is still attached to the window though. I tugged on it a little and it started pulling off but pushed it back on the window and it seems to be attached pretty good. Does that need to be taken off and re-stuck to the window?
I guess I need to pull up the old electrostatic sticky thing?
Old Aug 29, 2014 | 09:05 PM
brgjag's Avatar
if it comes down to it I don't car if the rain sensing thing works to be honest, the car see's little rain. I just want all of the darn mirror stuff back up and not falling off. Looks like I can pull off the round sensor thing? When I do will I need new adhesive for it when I put it back on?
Old Aug 30, 2014 | 08:45 PM
enderle's Avatar
Default Mirror
The self dimming component in the mirror uses a very caustic liquid and it is prone to fail and then leak particularly if it gets hot if that is leaking get the mirror replaced do not reattach it. DO NOT LET THAT LIQUID TOUCH YOU OR ANTHING IN YOUR CAR it is nasty stuff. I don't recall it being black though so it is possible that someone used some substandard adhesive which has melted in the heat. Better safe than sorry though. If you remove anything you'll need a new adhesive back to reattach it the adhesive is generally single use only. The part number for the new adhesive was listed earlier in the string.
Old Sep 2, 2014 | 07:16 PM
brgjag's Avatar
I see no signs of leaks from the mirror. It is out of the car and I looked it over and see nothing.
Old Sep 2, 2014 | 07:18 PM
brgjag's Avatar
wife say she saw a blackish spot on the dash pad, I see nothing when I look. When it was half way hanging up there the rain sensor eye was, is coming off, I wonder if the black gue holding it on melted and dripped.
I am about to putt all crap down and attach a regular mirror up there. All that fancy **** is fine till it breaks, then it costs crazy money to fix.
Old Sep 2, 2014 | 07:21 PM
brgjag's Avatar
i was direct to this thread for loose mirror.
JagRepair.com - Jaguar Repair Information Resource
Mine does not have that clip that it shows there. Arrrg,
Old Sep 2, 2014 | 07:38 PM
brgjag's Avatar
post 161
https://www.jaguarforums.com/forum/x...t-17719/page9/
mine does not look like that. i am ganna have to take pics
Old Sep 3, 2014 | 08:44 AM
brgjag's Avatar
This appears to be for the rain sensor. What do I need to hold the whole mirror assembly back on the window?
Old Sep 6, 2014 | 04:50 PM
brgjag's Avatar
Where do I get the black sticky stuff that you see in the pics I posted. You see at the center of it both sides of the sensor is where it pulled away allowing the mirror to come loose. The rain sensor is attached still. Where do I find that black piece that goes all the way around. I pull it all off since most of it was pulling up. That seems to be what was holding up my mirror.
Old Sep 6, 2014 | 05:02 PM
brgjag's Avatar
This is my mirror. The center circle sits over my rain sensor. On the flat metal circle there was a hard black adhesive of some type that held my mirror to the window I think.
Does any one know on this??? Seems everything I find here is pre 2003 and is diff. I don't even have a clip in mine as noted on the pre 2003 models. I just have that pressure metal that pushes on the sensor I think to keep tension on things.
Old Sep 6, 2014 | 05:03 PM
brgjag's Avatar
Default Pic of mirror
Pic
Attached Thumbnails 2003 Auto Dim/Rain sensor Rview Mirror lifting off-imag1548.jpg
Old Sep 6, 2014 | 05:05 PM
brgjag's Avatar
you can see where I have some of the black stuff scrapped off the round metal circle.
