2003 Jag tensioner questions
Old Feb 26, 2014 | 07:02 PM
noterman's Avatar
Default 2003 Jag tensioner questions
I have a 2001 XK8 with a bad engine due to chain failure. I have located a 2003 engine. Have all the chain/tensioner problems been addressed with the 2003 engine? The engine is more expensive to buy but would be cheaper in the long run, if I do not have to replace the timing chains and tensioners. I have been told a 2003 engine will fit a 2001. Thanks
Old Feb 26, 2014 | 07:40 PM
test point's Avatar
The '03 engines, as did the late '02s all had the metal tensioners. The '03 4.2L engines can be swapped but involve a lot of issues that will substantially increase labor cost. Here is some discussion on the subject:
https://www.jaguarforums.com/forum/s...63/#post177881
Old Feb 26, 2014 | 08:15 PM
noterman's Avatar
Default 4.0 2003 engine
I thought the 2003 engine was a 4.0. Did they change midyear?
Old Feb 26, 2014 | 08:20 PM
test point's Avatar
The '03 XK8 was a 4.2L. I believe that the '03 XJ8 was a 4.0L.
Then there is the difference between the US and ROW model years.
Old Feb 26, 2014 | 08:25 PM
noterman's Avatar
Default 2003 4.0 a27
Sorry I forgot to mention the engine was from a 2003 XJ8 sedan. The salvage yard wants $2000 for the engine. I thought with no chain/tensioner expense that might be the way to go vs a 2001 engine that I would have to replace the chains/tensioners.
Old Feb 28, 2014 | 09:18 AM
noterman's Avatar
Default Throttle body
The 2003 XJ8 4.0 engine I am looking at is missing the throttle body. Would the throttle body from my 2001 engine work on the 2003 engine?
Old Feb 28, 2014 | 09:29 PM
motorcarman's Avatar
All AJ27 Normally Aspirated 4.0 engines will bolt into your 2001 XK8.
The throttles are the same.
Really the only difference in the 2003 XJ8 is the primary silent chain and oil pump setup.
All the ancillary parts will bolt on and plug up.
I can't think of any real differences.
bob gauff
Old Mar 27, 2014 | 08:50 AM
harveysjag's Avatar
01 xk8 I just had an issue with my engine, is this year and model know for having tensioner and timing belt issues? Is it repairable or do I need a new engine?
Old Mar 27, 2014 | 09:22 AM
Jag#4's Avatar
The 2001 MY does have the plastic tensioners and they should be replaced. Timing belts are no better or worse than any car, but are easily replaced.
As to your engine issue, it depends. What kind of issue do you have? Your description is a little too vague to offer any suggestions and why do you think this issue is tied to the tensioners?
xjrjag
Nov 27, 2025 09:16 AM
Bcrary3
Sep 12, 2015 08:43 AM
kesslari
Aug 31, 2015 10:20 PM
Bcrary3
Aug 31, 2015 11:29 AM
Andrew McVey
16
Aug 27, 2015 07:21 PM
