2003 XK8 occassional no start
Old Feb 16, 2021 | 05:32 PM
Pantera928's Avatar
Default 2003 XK8 occassional no start
If I go out to start this car when, it will either start right away or crank over like I disconnected the spark coils and refuse to fire. I can go out a few hours later and it starts right up and runs like nothing was ever wrong.
It never does this when it is stopped after being warmed up.
This has happened 3 or 4 times over the last 6 months..
Yes, battery is good and charged.
Reminds me of the old days when a XKE would not start because the points got wet from rain or condensation.
Any ideas?
Old Feb 16, 2021 | 05:50 PM
NBCat's Avatar
What is the battery voltage across the terminals with the ignition in the OFF position when measured with a voltmeter?
What is the fuel pressure during a no-start event? Use a smart phone with the Torque app to communicate with the vehicle PCM through the OBD port via a Bluetooth interface to read the fuel pressure. There should be around 3 bar with the ignition in the ON position prior to engaging the starter motor.
Old Feb 16, 2021 | 09:53 PM
Riley VanSuetendael's Avatar
I had a similar issue with my 97. It would crank over just fine but refused to start. Check to see if you have fuel pressure and spark. If you still have fuel pressure and spark, it could be the same issue I had, which was a failed "transmission rotary switch."
Old Feb 17, 2021 | 07:17 PM
Pantera928's Avatar
Thanks gentlemen
Battery voltage is fine. 12.6. This car lives on a tender when not in use.
Will check the fuel pressure. Great idea and so obvious I should have already done it. Thanks.
First I have heard about a "transmission rotary switch". Not even sure what that is.
FYI, it started and ran fine today after nothing new being done.
I think I have seen a correlation between "no start" and rain.
The car sits under a cover outside sometimes and I do believe that every time this has happened, there has been a rain storm the previous day. Not 100% sure on that.
Old Feb 17, 2021 | 09:14 PM
xalty's Avatar
verify fuel pressure at rail
is it ever used on very short trips?
Robert Grisar
Feb 3, 2021 10:20 AM
rieyaaznarodien
Sep 14, 2020 02:34 PM
carguy1996
XJ40 ( XJ81 )
Jul 11, 2014 11:00 AM
zibby_uk
Jul 18, 2011 11:12 AM
mark@ddi
Jan 27, 2010 12:24 PM
