2003 XK8 P/S fluid level should be?
Old Apr 30, 2015 | 02:18 PM
brgjag's Avatar
Default 2003 XK8 P/S fluid level should be?
Mine level has always be up right at the top of the small round hole opening where the dipstick goes in. Is that the correct spot? That black dipstick is worthless for reading I think.
Old Apr 30, 2015 | 02:52 PM
DpezXK8's Avatar
This out of the 2007 workshop manual but the setup is the same. Still use the steps on the cap for min max.
See Attached PDF
They specify the dexron 3 for the fluid (it's a FORD thing) so may want to check your owners manual before adding anything.
File Type: pdf
Old Apr 30, 2015 | 05:52 PM
brgjag's Avatar
ok, do you check it cold or hot?
Old Apr 30, 2015 | 07:36 PM
DpezXK8's Avatar
Don't think it matters, not like your oil.
If it's low top it off.
I usually check before I start the car.
aholbro1
Dec 29, 2024 06:46 PM
Jandreu
Jun 30, 2022 03:10 PM
abonano
25
Sep 25, 2015 10:43 AM
Wolfy
Sep 10, 2015 09:50 AM
David Thompson
Sep 3, 2015 07:48 PM
