2003 XK8 sometimes starts and others no.
Old Feb 26, 2023 | 06:03 PM
  #81
Pantera928's Avatar
Okay, to respond first to pistnbroke, that answer really does no help. This thread has been ongoing for quite a while.
There is no spark when this happens and if you hit the schrader valve, you get a strong spray of gasoline and in the face if you are not careful. Don't recall the pressure but I did test it once and it was good. Once the car starts, it runs fine.
I have several different OBD readers and none ever show anything. Not just the Mongoose
That is what makes this so aggravating. If it would stay broke long enough for me to do more troubleshooting, I would find it but it is hard to find something when it isn't there any more.
Old Feb 26, 2023 | 06:36 PM
  #82
xalty's Avatar
learn your car, do the diag and make the call. go through ids datalogger and look at some pids that might be helpful
http://jagrepair.com/images/TSB/TSB2...XK%20specs.pdf
http://jagrepair.com/images/Electrical/XKElectrical/XKTechGuide/2003%20MY%20XK%20Technical%20Guide.pdf
Old Feb 27, 2023 | 12:01 PM
  #83
Pantera928's Avatar
Good information but not much new that i did not already know. Wish that was not the case.
Old Feb 27, 2023 | 12:23 PM
  #84
Pistnbroke's Avatar
If the fault does not exist 24/7 then you have to go into substitution mode .
Ie study the diagram and say " what if it was a faulty ??? " and substitue a bypass for the fault you suspect and see if it puts it right . Eg bypass the earth system , provide another ignition live etc. It must be something that cuts all the igniton so that shuts it down .
Not easy if you are not an auto electrician
Old Feb 27, 2023 | 12:46 PM
  #85
Pantera928's Avatar
I get it and BTW, I used to consider myself a damned good automotive electrical guy until this car. That is what I have always specialized in and apparently, Jaguars are much more deceptive than Alfas or Porsches
Old Feb 27, 2023 | 02:58 PM
  #86
michaelh's Avatar
There is no spark when this happens.
So you have established that. OK - next question is why no spark?
For starters, can you wire a tell-tale lamp here semi-permanently between any R/W wire and ground? That at least will tell you if you have B+ to the coil packs when the fault occurs:
You may or may not have an ignition coil relay. If you do, it's here:
Old Feb 27, 2023 | 03:41 PM
  #87
Pantera928's Avatar
Will do that. its an easy test.
Old Feb 28, 2023 | 02:21 AM
  #88
Pistnbroke's Avatar
Crank position sensor or its wiring ?
Pull the relay in the diagram and re insert with a thin wire in turn to 1,3,5 with a small bulb to earth and see if you loose supply.
If yours has the two igniton boxes I assume you have checked those.
Smokey59
Nov 27, 2022 12:02 AM
Pantera928
Jun 30, 2022 03:28 PM
Cosmo2020
US Southwest
Jun 16, 2017 04:45 PM
MrS
Jul 6, 2012 05:31 PM
