2003 xkr purge control valve
Old Mar 23, 2011 | 08:35 AM
jimcaneer's Avatar
Default 2003 xkr purge control valve
Hi I have to replace my purge control valve dose anyone no how to
Old Mar 23, 2011 | 10:07 AM
RCSign's Avatar
Jim, the JTIS has a step by step procedure. Go make 9 more post to on the forums and you can download the JTIS off of the sticky's. It looks to be a simple job. Go introduce your self and welcome to the forum. You'll find a wealth of information here.
Doug
2001 XKR Silverstone
Old Mar 23, 2011 | 11:45 AM
WhiteXKR's Avatar
Remove the left hand front wheel, and the plastic wheel well liner. This will expose the purge valve on the right side of the wheel well. It should be a pretty obvious swap from there. An electrical connector and 3 or 4 hoses will need to be disconnected and 2 or 3 bolts removed. Be sure to check the hoses for deterioration and replace if necessary.
Old Apr 7, 2011 | 05:39 PM
djpxk8's Avatar
I want to change my purge valve as in Tech Bulletin 303-63.
When you say Remove the left hand front wheel is that standing in front of the car and looking at the bonnet (hood) or is it when sitting in the driver's seat??
Also, when reading TB 303-63 it says to replace the hose and filter, showing the filter sitting next to the brake master cylinder. When I look around my brake master cylinder there is No hose or Filter?? My car is a 2001 XK8 which is supposed to be covered by this TB (1999-2002 MY XK range).
Any help will be appreciated, ny wife says the smell must go!!
Old Apr 7, 2011 | 06:34 PM
RCSign's Avatar
DJP That's sitting in the drivers seat
Doug
Old Apr 7, 2011 | 06:42 PM
WhiteXKR's Avatar
-As Doug said, the convention of left and right in an automobile is always from the drivers seat perspective.
-Regarding the hose and filter in the TSB, they are new additions for use only with the redesigned purge valve...that is why you do not see them on your car.
Old Apr 7, 2011 | 06:45 PM
WhiteXKR's Avatar
BTW, TSB 303-61v2 also applies to fuel odor.
Old Apr 7, 2011 | 08:57 PM
djpxk8's Avatar
What is the part number for the purge valve I need to order for my car?
Old Apr 7, 2011 | 09:00 PM
djpxk8's Avatar
Just to confirm when I am sitting in the driver side, the left hand side is the passenger side...yes?
Old Apr 7, 2011 | 09:10 PM
WhiteXKR's Avatar
LJG1515BB. Al the part number are on page 4 of TSB 303-63.
Old Apr 7, 2011 | 09:12 PM
WhiteXKR's Avatar
No. It is the same perspective as when you are driving (ie; left side = left turn, right side = right turn). The passenger side is the right.
Old Apr 7, 2011 | 09:19 PM
djpxk8's Avatar
sorry to appear stupid, but you are saying, under the wheel arch which has the brake master cylinder above it...yes? which is the side my wife sits on when I am driving.
Old Apr 7, 2011 | 09:24 PM
WhiteXKR's Avatar
Yes, the side with the brake master cylinder.
Old Apr 7, 2011 | 09:26 PM
djpxk8's Avatar
do we have a list of jaguar parts suppliers with discounts, to buy from the internet?
Old Apr 7, 2011 | 09:32 PM
WhiteXKR's Avatar
Try Jaguar Parts Center - Call (800) 510-1401 for Genuine Jaguar Parts and Accessories online
or
Nalley Jaguar
http://www.nalleyjaguar.com
Phone number: 888-531-2266
11507 Alpharella Hwy
Roswell, GA 30076
(order by phone, but free shipping and 15% off over $25 for forum members)
Skeeter
Sep 17, 2015 08:15 PM
OkieTim
Sep 8, 2015 04:48 PM
colorancher
Sep 5, 2015 01:40 PM
edtexas
Sep 5, 2015 10:49 AM
colorancher
Sep 3, 2015 02:29 PM
