2001 Jaguar XKR Convertible - Steering wheel fluid leakage
Old 07-14-2018, 07:30 PM
20adam1's Avatar
Default 2001 Jaguar XKR Convertible - Steering wheel fluid leakage
Initially, the amount of steering wheel fluid loss was minimal and wasn't readily noticeable until realizing the squeaking sound that goes along with turns. In hindsight, any leakage may have burned off from the heat of the engine
In topping off of fluid, squeaking and any reduction of turning went away until fluids needed refilling.
However, most recently, the leaking of fluids has become substantial as evident by that which is left below the vehicle on the pavement, driveway, and garage. Suffice to say, the vehicle is not practical to drive and looking to understand the extent of the repair need.
Again, as long as fluids are topped off, the steering limitations and noise are not an issue but going to the station and asking to fill up the steering fluid and check the gas is not the obvious way to go.
Old 07-15-2018, 06:10 AM
GGG is online now
Received 16,800 Likes on 12,169 Posts
Welcome to the forum 20Adam1,
I've moved your question from S-Type to XK8/XKR forum. This is the place to post technical questions about your model.
Don B (07-15-2018)
Old 07-15-2018, 07:29 AM
Jon89's Avatar
Received 4,276 Likes on 2,813 Posts
The most common source of a power steering fluid leak in these vehicles occurs at the metal tube-to-rubber hose coupler joint located just below the air filter box and next to the alternator. Some of us who have suffered this leak have opted to cut the leaking coupler out of the system, connect an appropriately-sized rubber fuel line or rubber transmission line hose section to the lower metal tube portion, and then use an appropriately-sized brass hose barb connector to attach the new rubber hose section to the existing rubber hose section above it. The cost of this repair is typically under $10 if you do it yourself, and the required parts can be purchased at most auto parts stores such as NAPA. Wayne (cjd777) and I performed this repair on my wife's 2006 XK8 back in February, and not a drop of power steering fluid has leaked since. Search the XK8 section of the forum using the phrase "power steering fluid leak repair" and you will find multiple threads describing various ways to accomplish this repair (assuming of course that you discover that your coupler joint is indeed the source of your leak)….
Don B (07-15-2018)
Old 07-15-2018, 03:43 PM
Robert Grisar's Avatar
I had the same issue with my 2001 XKR. I kept topping off the steering fluid, thinking that I could live with it. WRONG. So one day I asked my wife to help. In the garage, she sat behind the wheel. Started the car. I got down to look under the engine. When she turned the steering wheel to the left or right, I could see exactly where the fluid was leaking. (I'm a trusting sole to get in front of the car with my wife at the controls). Anyhow, this repair was beyond my capability. Took the car to my local mechanic. He ordered a used steeping pump and new high pressure steering lines. Cost out the door was $640, and well-worth it. Car again steers (and tracks) just like when it was new.
Old 07-15-2018, 04:15 PM
frankc's Avatar
Look up Lubeguard (not sure of spelling) on Amazon then take a look at the reviews. You may find it interesting.
Here you go. Scroll towards the foot of the page for the reviews.
Amazon Amazon
I do not work for them.
Don B
General Tech Help
17
08-08-2017 09:11 AM
stingray71
01-07-2017 03:44 PM
XKR8
10-24-2016 08:48 AM
Don B
General Tech Help
11-09-2015 12:59 PM
JimC64
03-02-2015 08:07 PM
Quick Reply: 2001 Jaguar XKR Convertible - Steering wheel fluid leakage
