2004 XKR window doesn't stay down to close door
Old Feb 14, 2013 | 10:54 AM
wesmc2's Avatar
Default 2004 XKR window doesn't stay down to close door
When I pull up on the handle the window drops like it is supposed to. When I release the handle the window goes back up, can't close the door smoothly. Is this usually a switch? Regualtor? Door control computer?
Old Feb 14, 2013 | 11:34 AM
WhiteXKR's Avatar
Have you performed a window reset yet? Hold down both window buttons for a few seconds untill you hear a soft click, then hold up both window button for a few seconds again until you hear a soft click.
Old Feb 14, 2013 | 11:52 AM
jimbov8's Avatar
Failing the reset procedure, locate and check the correct operation of the door switches, it could be that one is sticking.
Old Feb 14, 2013 | 11:55 AM
wesmc2's Avatar
Thanks..tried reset with no luck..I'll look at the switches
Old Feb 14, 2013 | 01:12 PM
Paul Pavlik's Avatar
The "Door Closed Switch", mounted on the Latch Assembly, inside the Door, has probably failed. Jaguar can supply the Switch only, as a replacement part.
Old Feb 14, 2013 | 03:03 PM
wesmc2's Avatar
thanks guys...that was it.
toronadomike
Jan 22, 2026 10:13 PM
Beardy
Sep 18, 2015 10:00 AM
tberg
Sep 7, 2015 07:32 AM
TC Johnson
Sep 2, 2015 09:30 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
