2005 XK8 door lock switch failure
Old Dec 21, 2015 | 03:29 PM
zidjan's Avatar
Default 2005 XK8 door lock switch failure
Hi guys,
My driver side door won't unlock...the door have no problem opening once it's been unlocked by either the passenger side or the remote...windows operates normally....any idea what seems to be the problem?
Old Dec 21, 2015 | 04:04 PM
jimbov8's Avatar
I would say you have a sticky lock. Will the door unlock with key?
Either way you are going to have to take the door card off to get to the mechanism which also means you will need a supply of clips to put the card back on again.
Try spraying the mechanism with a silicon spray before you start to spend any money.
Old Dec 22, 2015 | 08:03 AM
tberg's Avatar
Does your passenger door unlock? If both are not locking or unlocking, there is a 10 amp fuse for the locking mechanism located inside the passenger door on the end of the dash fuse panel. It happened to me a couple of months ago, and that fixed it.
Old Dec 22, 2015 | 10:41 AM
zidjan's Avatar
Do you know where the best way to buy those clips...just in case the one of the car broke?
Passenger door works just fine....once the door is unlock, the latch has no problem opening.
Old Jan 7, 2016 | 12:09 PM
zidjan's Avatar
Hey guys I forgot to say ... it's the door latch from the inside not outside....so the latch from the inside won't unlock the car...I have to use my remote or reach out to the passenger door to unlock the car and then the latch will have no problem opening the door from the inside.
Old Jan 7, 2016 | 02:17 PM
There's no getting away from it - the door card is going to have to come off to see what's wrong.
There's 2 rods and 1 cable connected to the Door Latch:
The BLUE rod goes to the exterior door lock. The GREEN rod goes to the exterior door handle. The RED cable goes to the interior door handle.
From your description, I suspect the cable has either become dislodged or is broken. Difficult to tell because the interior handle is spring loaded and has a resistance anyway when you pull on it even if the cable is disconnected.
Old Jan 12, 2016 | 03:20 PM
zidjan's Avatar
Just an update:
I ended up taking it to my Indy and they fixed it...they said it's dry and once they grease it or lube it whatever the term is...it's working succesfully.
Old Jan 12, 2016 | 03:23 PM
jimbov8's Avatar
Glad to hear you have it working again. Thanks for the update.
kesslari
Jun 28, 2016 02:01 AM
Jaguar Forums Editor
Jaguar Press release
Jan 12, 2016 11:14 AM
seraphi
Dec 20, 2015 12:12 PM
kyle04
Dec 19, 2015 10:43 AM
djakemc
Dec 15, 2015 01:00 PM
