4.2 L Diff. Plug
Old May 24, 2018 | 01:39 PM
RJ237's Avatar
Default 4.2 L Diff. Plug
I finally got the plug out today.
1.Removed the sway bar and unbolted the diagonal brace at the back.
2. Cut 1/2" sq. bar stock 1" long and maneuvered into the plug. It's best to stuff a rag in the gap below so you don't lose the bar stock when you drop it.
3. From the side slid a 14mm ratchet drive wrench over the bar stock.
4. Used a wrecking bar to break the plug loose.
Pumping the old oil out and refilling with the Mity Vac will be easy compared to getting the plug out.
juha_teuvonnen
May 25, 2016 10:37 PM
iownme
May 11, 2016 05:12 AM
lc3566
Jan 28, 2016 05:16 PM
liquidreality
Aug 9, 2014 07:41 AM
brucelee
Nov 21, 2011 10:14 PM
