97 Loose Door Mirror
Old Jan 5, 2016 | 11:54 AM
skubeedoo's Avatar
Default 97 Loose Door Mirror
On the driver's door mirror, the mirror itself, the glass not the housing, is loose, it wobbles when driving. Is there any documentation for tightening it up?
Thanks in advance
Old Jan 5, 2016 | 11:59 AM
jimbov8's Avatar
If I remember correctly it just clips into a housing at the back. It may just require a gentle push back to reseat it correctly.
Old Jan 6, 2016 | 04:24 AM
skubeedoo's Avatar
It feels like something's not tight inside, the mechanism. didn't know if there were screws that could be tightened or if the mechanism is shot.
Old Jan 6, 2016 | 04:27 AM
jimbov8's Avatar
The easiest way to find out is to pull the glass out and look at the mounting behind.
Old Jan 7, 2016 | 11:44 AM
skubeedoo's Avatar
What's the best way to pull the glass out?
Old Jan 7, 2016 | 11:52 AM
jimbov8's Avatar
Drive the glass to its innermost setting, for you that would be to the right. With your right thumb, press against the part of the glass that is closest to the door. Using your left fingers, place at the outside of the glass and slowly prise out.
Hope this helps you out.
skubeedoo
Jan 9, 2016 02:19 PM
andrew_sankus
Jan 9, 2016 08:54 AM
Gregor
Jan 6, 2016 06:29 AM
NtAFord
Jan 4, 2016 04:44 AM
JUNALUSKA BOY
General Tech Help
Jan 3, 2016 05:18 PM
