97 xk8 4.0 torque specs & sequence
Old Feb 28, 2019 | 01:51 PM
MDsjag's Avatar
Default 97 xk8 4.0 torque specs & sequence
Does anyone have this info for cam covers? I’m getting ready to install gaskets today? Your help is greatly appreciated.
Old Feb 28, 2019 | 07:42 PM
DavidYau's Avatar
Default Camshaft Cover Torque Sequence
Here it is. Don't forget the blob of sealant on the flat spot on the sealant.
File Type: docx
Old Mar 2, 2019 | 08:50 AM
MDsjag's Avatar
Much thanks David. Are you aware if codes will reset after replacing transmission? I just completed the job. 🤪
Old Mar 2, 2019 | 10:54 AM
DavidYau's Avatar
Default Codes reset
just changing the camshaft cover gaskets won’t reset any codes. Try the hard reset - removing -ve / ground lead from battery and touching the +ve battery terminal. Wait 10 min. That’ll reset most but not the transmission TCN. That’s only from the dealer, but you shouldn’t need that. If you still have codes, post that desperately on the forum for help
muttony
Jul 9, 2019 04:36 PM
volkris
Aug 19, 2018 02:33 PM
REDTYPE
Sep 28, 2015 12:08 AM
devivion
Apr 30, 2015 06:20 AM
First Jag XJR
Aug 30, 2013 09:11 PM
