97 xk8 drivers window and mirror problem
Old Jul 22, 2013 | 12:56 PM
matrixtinter's Avatar
Default 97 xk8 drivers window and mirror problem
I have a 1997 xk8 and before i did some modifications all was well. I put scissor doors on it and now I have limited control on the drivers side (LHD). the window will drop when handle is pulled but will not return up when door is closed. It works up and down with the switch fine and even after resetting the windows it still doesnt want to return to the up position. The passenger side works fine. Also the mirrors on both sides only go down and to the right. NO left or up on either of them. I replaced the drivers switch assembly but didnt correct the problem. I saw that there is a drivers door control module in the door is this the problem or is it fuse related?
Old Jul 22, 2013 | 01:06 PM
jimbov8's Avatar
Welcome to the forum,
Your window has probably lost its memory.
Put the key in the ignition to position 2.
Hold the window switch in the down position until you hear a faint click.
Power the window up and hold the switch until you hear another faint click.
You should then have problem solved, if not, try again.
Old Jul 24, 2013 | 08:39 AM
Default tried that
I tried that numerous times.. the passenger window works like it should but not the drivers side. Replaced the battery and drivers switch assembly but still the window does the same thing and the mirror only works 2 directions for both sides not all 4.
Old Jul 26, 2013 | 09:14 PM
switch doctor's Avatar
Default Jaguar Window Switch Issue
Sound like the regulator might be getting hung up. I would check it to see if the cable are all okay!
Old Jul 27, 2013 | 05:00 AM
Welcome to the forum matrixtinter,
Once you've eliminated faulty limit switches and harness breaks, then the Door Module has to be next on the troubleshooting list.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST section and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
toronadomike
Jan 22, 2026 10:13 PM
JarodL
Mar 7, 2024 01:39 AM
kelliott
May 31, 2022 05:26 PM
alpecsa
Sep 7, 2015 11:55 AM
David Thompson
Sep 3, 2015 07:48 PM
