97 XK8 Engine fault no code
Old May 3, 2016 | 10:54 AM
serhiy's Avatar
Default 97 XK8 Engine fault no code
Hi to all, need your help. I have 97 xk8 i owned it for 3 years. Car wont start at first attempt it cranks but wont start, engine fault massage displays and i have to wait couple minutes then massage go off and car start right away and run without any problem. But when i shot off engine and try to start it go again with same problem all the time, it seems the longer the interval beetwen start the longer i have to wait to massage to go off. There in NO code just massage. I checked the fuel pressure its fine, then i disconnect fuel injector and check if there is voltage when i crank the engine and no voltage when car wont start but after car start voltage is there like it should be. I did change the rotary switch on the transmission and that does not helped. I all so change the throttle body and still with the same problem...
Old May 3, 2016 | 11:13 AM
bladerunner919's Avatar
It wouldn't have been the transmission switch - the engine won't turn over if it thinks it's in gear. How are you checking the injector pulse? I assume you're not just putting a voltmeter across the terminals and are using something that shows frequency or pulse-width?
Old May 3, 2016 | 11:30 AM
serhiy's Avatar
I'm using a indicator light
Old May 3, 2016 | 11:31 AM
serhiy's Avatar
but voltmeter will work to..
Old May 4, 2016 | 01:53 AM
JagV8's Avatar
That's no good as a test. (And on some car systems a test light can cause damage.)
You could have a fuel problem or maybe a power/ground fault.
Old May 4, 2016 | 06:20 AM
jamdmyers's Avatar
Is the warning light Red or Yellow? it should be on along with the message.
Old May 4, 2016 | 10:07 AM
serhiy's Avatar
Yellow but no DTC code can be detected by my OBD2 reader. And no fuel problem.
Old May 4, 2016 | 10:12 AM
Are you just using a generic code reader, rather than something Jaguar-specific?
Old May 5, 2016 | 05:22 AM
jamdmyers's Avatar
Here is the list from jtis for 97 engine fault amber, sift through these:
I know you said you had no codes but these trip the indicators
Old May 7, 2016 | 12:18 PM
serhiy's Avatar
Yes, im using generic scan tool.
Old May 17, 2016 | 09:48 AM
serhiy's Avatar
Thanks to all, problem solved. Rotary switch cost the problem as i state before i did change switch once but looks like it was defective so i change it again and car start and run like new again.
34by151
May 6, 2024 12:20 PM
dinop
Jun 14, 2016 02:48 PM
David Burrill
May 5, 2016 05:10 AM
Rick Elliott
US Northeast
Mar 30, 2016 08:13 PM
