'97 XK8 - Poor Engine Performance
Old Nov 8, 2010 | 07:32 PM
JamesJag's Avatar
Default ECU Rebuild
Jagula -
Good luck - I hope it works out for you. Please post back with your results.
I'm up and running 2+ weeks now .... run'n great.
Old Nov 26, 2010 | 01:14 AM
Jagula's Avatar
Got my Rebuilt ECU back from the same place for the $400. Jags been running fine for a couple weeks now. I do have a P1227 code that comes up from time to time. These same folks will Rebuild the throttle body for $295 which will save me from spending $1825 for a new one. And they will stand behind their work. Thanx again James for pointing me in the right direction.
Old Nov 28, 2010 | 06:44 PM
brgjag's Avatar
These the guys that advertise on Ebay?? Is this them??
http://cgi.ebay.com/ebaymotors/JAGUA...Q5fAccessories
This person has a sale going on the reblds.
Old Nov 29, 2010 | 07:16 AM
xjrguy's Avatar
That's them. I had one of our owners send his XK8 ECM to them on one of their Ebay ads. Worked perfectly when plugged in. I'll be using them for the next throttle body and see how it goes.
Old Nov 29, 2010 | 03:58 PM
Jagula's Avatar
My 97 XK8 Coupe is still going strong. I sent them a note asking about my P1227 code referring to the Mechanical Guard Circuit in the Throttlebody. They knew excatly what caused it and what it needed. They even told me what to remove and send without sending the entire throttlebody. I highly recommend folks to call or e-mail them with engine or module code issues. Here's a link to their ebay store. http://stores.ebay.com/ABS-ECU-ECM-E...MPUTER-REBUILD
Hope this will save you folks some money.
Old Nov 29, 2010 | 07:04 PM
brgjag's Avatar
After going back and forth with them today the ECM goes out tomorrow from my car, so what is cooking there. They do this good work as folks are reporting, they will be in work for a long to come with all these Jags on the roads with these electronic ticking time bombs scattered within them, ha ha ha.
Old Apr 5, 2022 | 07:18 PM
DaddysJag's Avatar
Default Ecu rebuild
The link doesn’t direct u to the site? Do you have an alternate link?
Old Apr 5, 2022 | 07:53 PM
  #28
RJ237's Avatar
You are attempting to communicate with a 11 year old thread. It does sound like a typical 97 ECU failure is coming. Try doing a google search of ECU repair. I think some one in CA had it done in the past several months.
Old Apr 6, 2022 | 02:59 AM
Pistnbroke's Avatar
Rebuilt ECU ..?? the only bits that go bad are the electrolytic capacitors and you can change them yourself if you are good with a soldering iron ..they cost peanuts.
Old Apr 6, 2022 | 09:21 AM
  #30
DaddysJag's Avatar
Default Poor engine performance
ok got it I’m new to the site.
toronadomike
Jan 22, 2026 10:13 PM
99xk8guy
Sep 29, 2025 10:51 PM
D.K
Dec 10, 2023 02:05 AM
scottatl
Sep 4, 2015 08:08 PM
XFR_Gold
Sep 2, 2015 12:24 PM
