97 Xk8 TB swap
Old Nov 18, 2010 | 11:21 AM
brgjag's Avatar
Default 97 Xk8 TB swap
The TB on my 97 appears to be dead. Is the process of taking it of and putting a rebuilt in it's place hard? It look like tight back there but any special tools needed?
Old Nov 18, 2010 | 07:17 PM
brgjag's Avatar
Anyone?
Old Nov 18, 2010 | 07:50 PM
H20boy's Avatar
sorry, didn't take mine off before...bump for someone who has
Old Nov 18, 2010 | 10:16 PM
XKRacer's Avatar
No special tools needed 45 minute job, the trickiest bit is getting the water pipe off
Old Nov 19, 2010 | 12:56 PM
OregonJag's Avatar
It's easy enough to remove that I pull it off just to make room to work on the hoses back there. Ditto on the water pipe but you can nurse it off, be patient.
Mike
Old Nov 28, 2010 | 06:49 PM
brgjag's Avatar
where is the water pipe? Which side? Special tools needed or will my typical stuff to work on cars work? I am thinking about starting to pull it to have it replaced. If that does not do it then the computer goes out for repair.
Old Nov 29, 2010 | 01:42 AM
XKRacer's Avatar
As you are looking at the car it is on the right hand side but it connects to the block on the left via a steel pipe coming from just above your starter motor, you might find it easier to disconnect from there.
willtoliv
Oct 2, 2015 12:18 PM
speacock
Sep 25, 2015 02:58 AM
Jagged-X
Sep 24, 2015 05:08 PM
Lawrence
XJ40 ( XJ81 )
Sep 18, 2015 02:03 AM
Bowman
Sep 3, 2015 03:17 PM
