97 xk8 when should i change the atf
Old Jun 13, 2011 | 09:22 PM
Felipe Pr's Avatar
Default 97 xk8 when should i change the atf
My 97 xk8 have 34,000 miles and is running perfect. I bought it september last year with 31,500 miles and immediately worked out the tensioners, thermostat, shock mounts, power steering hose/oil cooler and some other minor things here and there.
The only major not done yet is the change of the atf/filter, which by the way, is working perfect
when, at what time/mileage is the most proper time to do it?
Old Jun 14, 2011 | 05:08 AM
test point's Avatar
Jaguar specified that the ATF was 'lifetime' which has proved to mean until the transmission failed. ZF now recommends a 60k change interval on their rebuilt transmissions.
The most significant internal failure has turned out to the physical failure of the 'A' drum which has little or nothing to do with the ATF.
Lots of discussions on the subject and sources of ZF spec fluid or fluid that specify meeting the specs in the FAQ sticky above.
Old Jun 14, 2011 | 11:24 AM
GordoCatCar's Avatar
Agree with TestPoint. I think you're safe with ATF until at least 60K.
Some BMW's have the same ZF_5HP24 trans as our '97. Originally BMW said it was a lifetime ATF fill; now they indicate 100K is the correct mileage for a replacement fill. Consequently I think everyone should change their trans fluid sometime between 60 and 100k; with sooner being better than later.
ZF 5HP24 transmission - Wikipedia, the free encyclopedia
99xk8guy
Sep 29, 2025 10:51 PM
aholbro1
Dec 29, 2024 06:46 PM
99xk8guy
May 28, 2024 09:36 PM
David Thompson
Sep 3, 2015 07:48 PM
Bowman
Sep 3, 2015 03:17 PM
