98 to 2002 timing chain difference
Old May 7, 2014 | 05:56 PM
rumm5's Avatar
Default 98 to 2002 timing chain difference
Are the timing chains and guides different between 98 and 02? I can get a better price on a kit for a 2002 with metal tensioners, chains and guides. If they are different, are they a direct bolt in upgrade?
Old May 7, 2014 | 07:53 PM
test point's Avatar
The '02 MY upgraded to the chain/sprocket of the 4.2L engines in February of '02. They are different from the earlier ones. You do not identify your car but if it is the older version you need to order that version. The tensioners are the same.
way2far
Aug 31, 2022 09:26 AM
SD96XJ6L
Jan 12, 2022 04:30 AM
Raul Lara
Sep 14, 2015 07:31 PM
tberg
Sep 7, 2015 07:32 AM
Sprayall
Sep 3, 2015 07:49 PM
