98 XK8 oil restriction
Old Oct 9, 2008 | 09:19 AM
dugem260's Avatar
Default RE: 98 XK8 oil restriction
Have you tried using Berryman Chemtool? I haven't used it in my Jag but I have used it previously on a sludgey oil system in another car. Check with local auto parts supply for their recommendations also.
Doug
Old Oct 9, 2008 | 12:24 PM
Brutal's Avatar
LOL, FIND SOMEONE ELSE, I WOULD MORE SUSPECT 1,CARBON DEPOSITS IN THE COMBUSTION CHAMBER, 2,POSSIBLE LOOSE VALVE SEAT(THEY DROP AND YOU HAVE NO COMPRESSION) 3 AND MORE LIKELY IS TIMING CHAIN NOISE FROM BAD UPPER TENSIONERS, PULL CAM COVER OFF AND INSPECT, IF THEYRE PLASTIC STYLE REPLACE WITH METAL BODIED NEW STYLE AND SHORTER BOLTS. BUT THEN AGAIN i CANT HEAR YOUR ENGINE ON THE NET
Old Oct 9, 2008 | 05:19 PM
Brutal's Avatar
WELL SINCE YOUVE ALREADY UNDATED TENSIONERS, THE NEXT MOST COMMON TICKING NOISE IS THE VVT'S, SHORT OF REPLACING CHANGE YOU OIL AND GO TO 40-50W AND SEE IF NOISE GOES AWAY, OR LESSENS.
99xk8guy
May 28, 2024 09:36 PM
mrplow58
Jan 21, 2024 05:53 AM
kelliott
May 31, 2022 05:26 PM
giandanielxk8
Sep 6, 2015 07:21 PM
XFR_Gold
Sep 2, 2015 12:24 PM
