98 XK8 won't start, then starts
Old Jan 24, 2012 | 01:29 PM
hawkeye's Avatar
Question 98 XK8 won't start, then starts
Cold start, wouldn't crank. The only sound was clicking from the rear, probably the fuel pump. It ran thru System Check, and CHECK ENG stayed on. Got the same result in both P and N. Battery was fine.
Let it sit for an hour. Then it started and ran normally, with no CHECK ENG. Has been fine for 3 days.
Is this a sign of something worse to come? Thanks!!
Old Jan 24, 2012 | 02:27 PM
test point's Avatar
It is probably going to happen again. Check the several connections from the battery to the engine fuse panels. Loose and/or corroded high current connections are a common problem.
Old Jan 24, 2012 | 11:28 PM
H20boy's Avatar
Neutral safety switch is my bet if the battery is good and you have full gauge readings...jiggle in P or N next time and turn the key w/o waiting an hour That is a random one, which can be looooong times inbetween occurrences, or happen twice in a row frustrating issue.
Old Jan 25, 2012 | 09:20 AM
nine7xk8's Avatar
these cars have beautiful bodies on them. i wish there was a way to clean out that engine compartment and just put a whole new engine and setup in it. like a 5.o with a standard transmission like on hot rod t.v.
Old Jan 25, 2012 | 11:04 AM
Spurlee's Avatar
Oh, there is. Check the forum for recent posts about swapping in a GM V-8 unit.
Old Jan 25, 2012 | 02:48 PM
Steve8's Avatar
I'd bet on a loose or bad connection before I started looking at the electronics in the car. This kind of symptom is common enough in all cars, I experienced it myself in a 1963 Corvair (NO electronics, unless you consider the transistors in the radio). Found the positive battery cable clamp wasn't QUITE clamping down on the battery post. Nut was so tight it almost twisted off, and felt snug, but found that all I was doing was clamping the two sides of the connector together. It wasn't until I replaced it with a new cable, where the connector solidly clamped onto the terminal that the problem went away.
Old Jan 26, 2012 | 06:30 AM
nine7xk8's Avatar
yeah i seen the post of the v8 and it just dont seam worth the money. i would rather just get the 4.0 and gear box together. im looking aroung 3000 for a piece of mind.
Old Feb 7, 2012 | 05:26 PM
hawkeye's Avatar
Smile Thanks!!!!!!!!!
Here's the rest of the story.
I called my independent Jag mechanic about this. He said could be a bad chip (or maybe he said code) in your key. I said Aha, brilliant, but I'm using the extra key you sold me. We both laughed.
Anyway, later I was in for service and he checked the electrical gremlins you all suggested. Turns out the negative battery cable was loose on its post. Dumb, simple, but cheap.
So.......now we know.
Thanks for your suggestions!!!!!!!!!!!
99xk8guy
Sep 29, 2025 10:51 PM
dsnyder586
Dec 29, 2024 07:39 PM
JarodL
Mar 7, 2024 01:39 AM
Charlene n John
Sep 28, 2015 06:01 AM
Broken_Spanners
Sep 6, 2015 11:34 AM
