99 XK8 MAF Replacement
Old May 20, 2014 | 03:58 PM
turbo68's Avatar
Default 99 XK8 MAF Replacement
I am wanting to replace my MAF Sensor and wondered if the ebay one here if fine for replacement.
Mass Air Flow Sensor MAF for Subaru Impreza Forester 2 0L 2 5L 22680AA310 | eBay
I have tried to clean mine with CRC cleaner but it still get P0171 and P0174 from time to time. Actually...when i removed the unit the o-ring was not in the best of shape. So if someone knows where I can get that size of o-ring that would help too.
Thanks in advance!
Mike
Old May 20, 2014 | 04:50 PM
jonscot's Avatar
Mike, I ordered one of these - should arrive this week. I'll let you know if it works ( 2000 XK8 )
Old May 21, 2014 | 08:01 AM
turbo68's Avatar
Thanks! I would appreciate that.
Old May 22, 2014 | 07:29 AM
jaguarbill's Avatar
Mike,
I'm in Bentonville, AR and I have a MAF from my 98 XJ8 non-turbo. I replaced it doing diagnosis and it was not faulty. You're welcome to it if it will work on your car. Non-turbo should be the same.
PM me if you want it.
Bill
Old May 22, 2014 | 08:16 AM
jafari's Avatar
Thumbs up
According to a supplier, all of the following cars have the same mass air sensor:
2000-2003 Jaguar Vanden Plas Exc. Supercharger
1999 Jaguar Vanden Plas
1999-2003 Jaguar XJ8
1999-2002 Jaguar XK8
2010 Mazda 3 2.3 Liters
2007-2009 Mazda 3 Turbo
2006 Mazda 6 Turbo
2010 Mazda CX-7 2.3 Liters
2007-2009 Mazda CX-7
2007 Mazda CX-9
2005-2006 Saab 9-2X
2004-2007 Subaru Impreza
2002-2003 Subaru Impreza 2.0 Liters
2008-2009 Subaru Legacy 2.5 Liters Turbo
2008-2009 Subaru Legacy 3.0 Liters
2004-2007 Subaru Legacy
2008-2009 Subaru Outback 2.5 Liters Turbo
2008-2009 Subaru Outback 3.0 Liters
2004-2007 Subaru Outback
2006-2007 Subaru B9 Tribeca
2004-2006 Subaru Baja Turbo
2004-2010 Subaru Forester
2008-2010 Subaru Tribeca
The MAF I have on my 2002 XK8 was salvaged off a Subaru and works fine; it has the same Denso part number as the one it replaced.
Happy Swapping!
Old May 22, 2014 | 09:48 AM
jonscot's Avatar
Default subaru MAF seems to work
Installed my ebay unit today - so far, seems to work perfectly.
Old May 22, 2014 | 02:31 PM
srad34's Avatar
This is a great tip, thankyou!
Old May 23, 2014 | 09:00 AM
turbo68's Avatar
Thanks for all the feedback. I also thank jaguarbill for the offer! Doing major work on my house right now and just no able to get down there but thank you again. I will just order the one off ebay and give that a shot.
Thanks again... just gotta love this forum!!!
Old May 27, 2014 | 11:17 PM
Hamish's Avatar
Default MAFS O-Ring
For what it's worth, I found a replacement o-ring at my local ACE Hardware in Plumbing. Typical Sunday, cleaned the MAFS and the o-ring was split. Hence the trip to ACE.
If ever I get the "death rattle", I'm hoping that Briggs & Stratton use the same secondary chain tensioners.......
Cheers,
Hamish
2001MY XK8
Old May 28, 2014 | 07:07 AM
aode06's Avatar
The computer uses the top 02 sensors,coolant temperature sensor,knock sensors and maf for a safe air to fuel ratio and timing table purpose combined.
The following are what Ive always done.
1.Add a large bottle of techtron fuel injector cleaner to just a 1/2 tank of gas
run it to 1/4 tank.
2.Replace the fuel filter.And refill with 93 octane to a half tank,*(why do we ignore the fact, these engines require premium unleaded,using less than that, will cause the knock sensors to retard your timing and make you xk8 a slouch).
3.Replace the front most top Oxygen sensors.
4.Replace the air filter.
5.Replace the MAF and O -RING.
6.Throw in a set of fresh ,properly gaped spark plugs.
7.Change the oil and filter as it has the fuel injector cleaner in the oil.
8.Replace the coolant temperature sensor.
9.Do a hard reset to erase the computer formal knowledge and have it adapt to the new repairs/relearn.
You will be amazed of your results,I typically, do not share this information
with too many people.
99xk8guy
Sep 29, 2025 10:51 PM
Forcedair1
Sep 8, 2025 01:57 PM
kelliott
May 31, 2022 05:26 PM
David Thompson
Sep 3, 2015 07:48 PM
KarimPA
Sep 3, 2015 07:32 PM
