99 xk8 woodrift key
Old Sep 30, 2013 | 04:17 PM
wjd03's Avatar
Default 99 xk8 woodrift key
Done alot of searching, with not too much luck on the crank bolt issue. First of all, am hoping the crank bolt turns lefty loosey to remove so I can get the balancer off. Second, does anyone know if there is a woodrift key that may have come out or sheared off causing the balancer to be loose? Any advice would be great,
Old Sep 30, 2013 | 04:59 PM
dsnyder586's Avatar
No woodruff key- just and INCREDIBLY tight one use bolt and cone washer.
Old Sep 30, 2013 | 05:19 PM
wjd03's Avatar
ok, so I am going to try and lock torqer coverter and use a breaker bar,,,,,,lefty loosey?
Old Sep 30, 2013 | 07:34 PM
dsnyder586's Avatar
If you crank the motor and look at the direction it spins, the bolt is the opposite. Some folks (DO AT YOUR OWN RISK and for heavens sake protect the radiator) have wedged the breaker bar between the ground and the car and bumped the starter to loosen the bolt.
I recall the if you look at the engine from the front, the engine turns clockwise, so it would be lefty loosey.
99xk8guy
May 28, 2024 09:36 PM
peterg19
Feb 10, 2023 09:02 PM
XJsc-guy
Nov 23, 2015 01:56 PM
picard
Oct 12, 2015 11:56 AM
picard
Sep 19, 2015 08:13 PM
