ABS fault diagnostic
Old Today | 08:07 AM
NorXKR's Avatar
Default ABS fault diagnostic
My ABS lamp in the dash lit up. No warning messages.
The ABS module has been repared once before, not by me but it looks like someone has cut a hole in the lid (and glued it back in) and i assume they have soldered the pins that normally goes wrong on these.
I have measured all four ABS wheel sensors at the module connector and they are all around 1080 ohms.
Is there anything else that could be the problem, or is it most likely a bad repair from the past?
Old Today | 09:11 AM
motorcarman's Avatar
You need the 'C' (chassis) DTCs to find what is wrong with the ABS.
Otherwise we can all guess?
Mad Hatter
Nov 20, 2023 04:18 PM
jagosaurus
Apr 29, 2022 07:14 PM
Doug Gordon
Apr 16, 2022 12:44 AM
Old Matelots
Dec 13, 2021 12:30 AM
GordoCatCar
Feb 15, 2018 07:28 AM
