ABS module from 97 xk8
Old May 4, 2013 | 11:41 AM
AkJag's Avatar
Cool ABS module from 97 xk8
Hello to everyone! I pulled my abs control mod out of my 1997 xk8 to see if the solder had broke. I did this after many dash board messages and the final- engine won't start. I have been through the forum and cleaned the sensors. The unit looked intact. It has a clear plastic coat over the entire board. Is there anything else to ck or should I send it off to be rebuilt? I sure appreciate all your input. Thanks Dan
Old May 4, 2013 | 11:46 AM
WhiteXKR's Avatar
Remove the coating at the connector to the motor and carefully resolder the two pins. The solder may have hairline cracks that are hard to see by inspection.
Old May 4, 2013 | 11:52 AM
AkJag's Avatar
Thanks I will give it a try. Does the coating just peel off?
Old May 4, 2013 | 11:57 AM
WhiteXKR's Avatar
Yes, just peel it off in that area, and clean it with a bit of alcohol before soldering for the best results. Use an electronics grade solder.
Old May 5, 2013 | 01:01 PM
AkJag's Avatar
Thank you whitexkr for you time and knowledge. I will try this soon and let you know if works. Thanks again Dan
Old May 5, 2013 | 02:34 PM
Jon89's Avatar
Just wondering how long the XK8 driving season lasts in Alaska....
Old May 6, 2013 | 10:45 AM
AkJag's Avatar
Hello jon89, well if we keep the top up, which I would rather not, we can run pretty much year round. But I run usually April to about September. Often during these times, if my heater is working well, I can sometimes drop the top. Thanks for asking. Dan
ericjansen
Dec 19, 2021 12:20 AM
picard
Oct 12, 2015 11:56 AM
flyrr100
Sep 29, 2015 03:47 PM
John Fox
Sep 19, 2015 07:56 PM
JeffinSwitz
Sep 16, 2015 01:44 PM
