ABS Module and Model Year
Old Feb 22, 2011 | 11:40 AM
Spurlee's Avatar
Default ABS Module and Model Year
Does anyone know hoe sensitive the ABS Control Modules are to model year? I have an opportunity to buy a "spare" unit from a 1999 model. Think it will work properly on my 2000?
Thanks!
Old Feb 22, 2011 | 01:24 PM
Spurlee's Avatar
It seems that there a re about 6 part numbers, so i guerss it's pretty sensitive. The P/N is easy to read, however, even when the unit is installed.
Old Feb 22, 2011 | 03:08 PM
xjrguy's Avatar
Generally speaking, if the part number suffix increments by a letter or two, you would be Ok. For instance, LNC2210AD would replace LNC2210AC. Also be sure the number of solenoid coils you see on the backside is the same; and the function designation is the same. I.E. ABS, ABS+TCS, ABS+TRACS. Steer clear of a PREFIX that is different, some are LJA, LJE, LNE, LNA for example.
Gee, harder to explain than it is to practice.
Cheers,
Old Feb 22, 2011 | 03:37 PM
Spurlee's Avatar
Understood. Can't see the soleniod coils without removing it, but the part number and product designation should get me most of the way home.
Wolfy
May 28, 2024 08:06 AM
PMKimpton
Aug 3, 2019 08:22 PM
Dz1rfj
Jul 17, 2018 10:29 AM
Dz1rfj
Sep 16, 2015 03:44 PM
edtexas
Sep 5, 2015 10:49 AM
