ABS Pump
Old May 13, 2009 | 05:53 PM
Joffa's Avatar
Default ABS Pump
Hi all
Have just had the car back from the dealer who was checking out a TRAC / ASC warning light.
They initially thought it was the nearside wheel speed sensor & harness which they changed - for $384.88 + tax (:-0). Light stayed on. OBD reported C1095 - something to do with the pump motor circuit.
They say it may be a false negative since they did a hard reset & the light went out, but they explained something to me about pump motor resistance. It went something like this...(transcribed as well as I recall)..
A new ABS pump motor would provide 0.7ohm resistance, mine was 3ohms
A new ABS pump motor voltage with key off would be 4.67v, mine was 1.07v
A new ABS pump motor voltage with key on would be 7.96v, mine was 7.96v
I'm told everything is OK & that everything is safe, but to go see them again if the light comes back on.
Any thought's?
Jof
Old May 13, 2009 | 07:41 PM
wheeble's Avatar
my ABS/stability control can be counted on to light up every three or four months. It usually clears with the clear button on the dash after one or two short trips. I am not concerned about the periodic fault on my car (1999 XK8).
When it stays on permanently, I'l fix it.
Old May 14, 2009 | 08:23 AM
Joffa's Avatar
Wow! Never thought about pressing the clear button to get rid of an error message before! Always thought it was just for the tripometer ;-)
How the blatently obvious smacks you in the face every once in a while!
Jof
ericjansen
Dec 19, 2021 12:20 AM
British Ride
XJ40 ( XJ81 )
Nov 28, 2015 03:50 PM
picard
Oct 12, 2015 11:56 AM
flyrr100
Sep 29, 2015 03:47 PM
xjrjag
Sep 24, 2015 10:08 PM
