ABS pump motor testing
Old Feb 26, 2015 | 01:29 PM
cruisin's Avatar
Lightbulb ABS pump motor testing
Mostly just a point of curiosity, but does anyone see any problem with testing the ABS pump motor by unplugging the lead and briefly jumping 12V to it, to make sure it spins?
Also. isn't there a relay somewhere to power this motor? I can't imagine it being powered directly off the circuit board.
Thanks,
Russ
Old Feb 26, 2015 | 01:46 PM
WhiteXKR's Avatar
Thanks,
Russ
The motor is driven electronically by power MOSFETS....no relays. It is probably 12 volts, but I have never verified it.
As you may have seen, the most common problem with the unit is broken solder joints on the motor connector to the circuit board.
Old Feb 26, 2015 | 08:23 PM
motorcarman's Avatar
THAT is EXACTLY how I test the pump when I get the C1095 DTC in a car I am diagnosing.
I have never seen a pump fail BUT.............. I always test the pump anyway.
It is a DC motor so a brief 12V burst will verify the pump operation.
It does not matter which lead is POS or NEG. You are not testing the pumping operation, pressure or flow, just the motor running.
bob gauff
dsnyder586
Dec 29, 2024 07:39 PM
ccfulton
Sep 20, 2015 05:15 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
1964Daimler
Sep 9, 2015 11:28 AM
Saturbo
Sep 8, 2015 07:35 PM
