ABS wiring connector
Old Apr 9, 2021 | 04:03 PM
alanroberts50's Avatar
Default ABS wiring connector
Hi the ABS unit (with all the brake lines) inside the hood has a multi wire connector at the bottom that I would like to disconnect and clean. Don’t want to mess up so can someone tell me how to disconnect it correctly? Is it easy?
thanks
Alan
Old Apr 9, 2021 | 11:13 PM
DavidYau's Avatar
Alan,
If you're referring to the ABS module and its rectangular multi-connector, yes it's easy to disconnect. (There are 2 electrical connectors).
The top of the connector is a square securing clip that needs to be pulled up (at a slight angle). You may need to wiggle the multi-pin connector as you try to pull the plastic securing clip up. Then the connector comes off easy. BTW there's another power type connector underneath - that's easier to deal with.
Old Apr 10, 2021 | 05:58 AM
RJ237's Avatar
Disconnect the battery negative cable first.
Old Apr 10, 2021 | 04:09 PM
Thanks so much was able to get both so peace of mind for now....
jagosaurus
Apr 29, 2022 07:14 PM
ryejag
Jun 24, 2019 10:52 PM
kenatofc
May 13, 2017 04:18 PM
bobe
Oct 23, 2014 07:54 PM
AlZee
Dec 17, 2011 08:16 AM
